Transmission and Primary Oil Change
Old 06-10-2008, 06:53 AM
95Heritage's Avatar
95Heritage
95Heritage is offline
Default Transmission and Primary Oil Change
Before everybody tells me to get a service manual, i already have one. I have&nbsp\\; been unable to find how to change the transmission and primary fluid in my Heritage. I know how to change the transmission but my question is does the bike need to be cold? Also what kind of fluid do you run in your transmission. I was told to run gear oil. I'm not sure on how to change the primary fluid. Any help would be great. Thanks in advance
&nbsp\\;
Old 06-10-2008, 07:19 PM
Asylumcycle's Avatar
Asylumcycle
Asylumcycle is offline
Default RE: Transmission and Primary Oil Change
should be screw @ bottom/change it warm,then fluids come out better and you get more of the"goo" out.
Old 06-10-2008, 09:10 PM
Other Sheep's Avatar
Other Sheep
Other Sheep is offline
See that big round cover with about five bolts in it on the left side of the primary? Drain bolt should be under that. Take it off to fill it back up again. Check your manual to see whether the bike needs to be on the stand or straight up. For the primary use a quality motor oil, 30w or such. Nothing fancy is needed there. For the tranny I use Mobil 1 synthetic gear oil, 75w/90 or 75w/140. Just my personal choice, others use amsoil, redline, purple stuff, pick one but synthetic makes the shifting much smoother.
Old 06-11-2008, 06:21 AM
95Heritage's Avatar
95Heritage
Thanks for the help. I got the primary oil drained last night but i was unable to find the drain plug for the transmission, any advise?
Old 06-11-2008, 06:46 PM
Asylumcycle
look right under your tranny side cover, you may have to look between the pipes depending on what pipes you have.
Old 06-14-2008, 02:06 PM
Other Sheep
Try between the shocks.
Old 07-11-2012, 07:31 PM
voyager1's Avatar
voyager1
voyager1 is offline
It is between the shocks.... You almost have to do it by feel. Hard to see. I belive it takes a 5/8 soocket,and a long extension. Caution. It is very easy to strip the threads putting it back in !!!!!!!!!!!!!!!!!! Don't ask me how I know .
Old 07-12-2012, 04:50 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,498 Likes on 4,612 Posts
It is not between the shocks, it is a small plug on the right side of the transmission, just below the cover that the clutch cable go into.
It is a torx, be careful when you re install the plug, it is a tapered pipe plug, and overtightening can cause damage.
Old 07-12-2012, 08:30 AM
cruisinmann's Avatar
cruisinmann
cruisinmann is offline
Received 1,807 Likes on 627 Posts
On softtails it is between shocks 5/8 socket ,it has a magnet pickup on it and a small o ring that needs to be inspected before reinstall.Replace o-ring if even slightly torn
Old 07-12-2012, 08:55 AM
SprungDave's Avatar
SprungDave
SprungDave is offline
Seriously?!? It is o.k. not to post when you do not know something.
Guys, not everyone has a twin cam.
The OP has an EVO engine, the tranny drain is NOT where our twin cam's tranny drain is. Dan89 is correct....
Quick Reply: Transmission and Primary Oil Change
