Starter relay wiring
Old 05-31-2008, 05:59 PM
1unclejojo's Avatar
1unclejojo
1unclejojo is offline
Default Starter relay wiring
I have a question on the wiring on the starter relay(the one under the battery tray).I have a 74 FXE. I have tried looking at my service manual and searching this forum and the internet,with no luck.The relay has 3 terminal posts.Two large and one small.
I was going to wire it..wire from handlebarswitch to the small post..wire from battery to one large post..wire from large post to solienod.Is that correct or am I asking for another smoking part??
Any and all advice is apperciated.Thanks in advance.
Old 05-31-2008, 06:27 PM
pococj's Avatar
pococj
pococj is offline
Default RE: Starter relay wiring
ORIGINAL: 1unclejojo
Handlebar switch to terminal #3, which should be the small one. Do not run a wire from the battery to the relay without fusing it, or using a circuit breaker. IIRC, the original wiring was battery - circuit breaker - bat terminal on voltage regulator - terminal #1 on starter relay. Terminal #2 on relay goes to small terminal on solenoid.
Old 05-31-2008, 09:34 PM
1unclejojo's Avatar
1unclejojo
Thanks for the response.I did forget to mention the circuit breaker.
With that info I should be able to button things upand maybe...get her back out on the road.
Being mechanically challanged(but learning fast!!).Trying to replace/repair someones quick fixes sure gives a guy a headache.Thanks to everyone on this forum....real helpful advice.
Old 06-01-2008, 02:20 AM
Rodney's Avatar
Rodney
Rodney is offline
Shouldn't their be the smaller bosh type relay wired in the system ?
first to the bosh type relay then to the larger starter relay?
Old 06-01-2008, 02:50 PM
pococj's Avatar
pococj
pococj is offline
ORIGINAL: Rodney
Nope, only one relay. They used several different types over the years. Some were physically bigger than others. Unless you're confusing the starter solenoid as a relay?
Old 06-03-2008, 08:08 AM
1unclejojo's Avatar
1unclejojo
Thanks for your help...I got the relay wired.It even worked correctly
Old 07-08-2012, 05:48 PM
MIDWESTZEOLITE's Avatar
MIDWESTZEOLITE
MIDWESTZEOLITE is offline
Stage I
Default Old style starter relay
Have an under the battery relay 77 shovelhead 4 posts 2 large 2 small( one marked I other S please what goes where
Old 09-06-2012, 07:52 PM
LoRydr's Avatar
LoRydr
LoRydr is offline
"S" is to the solenoid. "I" goes to ignition on some autos. Your relay can be used on different vehicles. Put tape or something over the I terminal. Don't use it.
Battery positive goes to one large post (either one). Other large post goes to the large post on the solenoid. (The one above the other large post that goes to the starter).
scarecrow 82
Electrical/Lighting/Alarm
03-19-2021 05:47 PM
jsa750k
EVO
10-08-2011 06:02 PM
inthamix
Ironhead
04-07-2009 04:33 PM
sutphen30
Ironhead
06-10-2008 08:15 PM
saweet96
07-15-2006 03:20 PM
Quick Reply: Starter relay wiring
