How do I set the time, FLHTCUI
This danged system has too many buttons and not enough info in the owner's manual.
I looked through the radio section 3 times and didnt see anything about setting the clock.
The only mention of the clock I found is for a bike with no radio.
If anyone has the Page number with the info it would be very helpful.
Thanks,
Fah
Thanks,
Fah
RE: How do I set the time, FLHTCUI
This is from memory and applies to an '08 Ultra:
With the ignition on, turn the radio off. You will then see the time in the display window. Look down at the lower right portion of the display window where you will see "set". Push the button next to the set indication and you will get a time up and time down adjustment option. It only lasts for a few seconds so be ready to adjust the time when you start the process. After you set the correct time, just leave it alone for a few seconds and the clock is now properly set.
aboatguy (08-20-2021)
