Sponsored by: Jekill and Hyde
Twin Cam 88 Horsepower Question
Old 05-28-2008, 03:20 PM
Tanker2's Avatar
Tanker2
Tanker2 is offline
Default Twin Cam 88 Horsepower Question
I just had my 1999 Ultra Classic Twin Cam Dynoed. I have 77 hp and 84 ft.lbs. of torque. Question what is stock 88 twincam horsepower? I have been told by the oringinal owner it has a stage 2 big bore kit. Would that be about right for that. I'm third owner. Last guy didn't know anything about it. So I contacted the first owner and that is when he told me it had a big bore kit. From the HP rating what do you guys think?
Thanks
Old 05-28-2008, 03:25 PM
thrillseeker's Avatar
thrillseeker
thrillseeker is offline
Default RE: Twin Cam 88 Horsepower Question
stock is something like low 60's for hp and mid 60's for tq.
I have a 95" stage I (stock cam) with a PCIII and it dyno'd at 80hp/88tq. I would expect a Stage II (i.e. different cam) would boost the numbers up at least a little, but not be lower.... in other words, your numbers seem a little low.
Old 05-28-2008, 04:44 PM
markymark02's Avatar
markymark02
markymark02 is offline
I have an 02 Fatboy stockwas 64hp and about 68 lbs of torque, with aThunderheaderS&S E carb, ignition and air filter I was around 79hp and 84lbs of tq. hope that helps
Old 05-28-2008, 08:18 PM
Tanker2's Avatar
Tanker2
Tanker2 is offline
Actually I miss spoke.I picked it up tonight. It's 77.09 hp at 90 max torque. It has Screaming eagleair cleaner, stage 2 camsand Rinehart true duals. It's a 1999 twin cam. Fuel air mixture is right where it should be.
Thanks
JIM
Old 05-28-2008, 08:58 PM
esyrdgcwby's Avatar
esyrdgcwby
esyrdgcwby is offline
Depending on what pipes you have on the bike that is about average , the best i have ever seen with a 95" kit from hd, with the 203 cams with no head work & a good set of pipes is around the low 80's , if you were to install a good set of pipes & cams you could get the bike up to the low 90s easy
ggadwa
19
03-23-2022 04:47 AM
HowBizarre
03-23-2018 07:44 PM
Bannana Boat
Milwaukee Eight (M8)
02-03-2017 12:28 PM
hddon24
01-12-2008 02:24 PM
2stout4u
EVO
11-04-2006 11:06 PM
Quick Reply: Twin Cam 88 Horsepower Question
