how do you check transmission fluid level?
Old 05-24-2008, 04:16 PM
freebyrd's Avatar
freebyrd
freebyrd is offline
Default how do you check transmission fluid level?
with bike standing up or on kickstand? and with plug threaded in or not, all i have is the owners manual and it says 32 oz for refill
is that correct?
freebyrd
Old 05-24-2008, 04:23 PM
big cahuna's Avatar
big cahuna
big cahuna is offline
Default RE: how do you check transmission fluid level?
most touring bikes trans oil is checked with the bike held uprite. I just rest the dipstick on the housing and fill it to the full mark on the stick . by doing it that way you might add a few more ounces then screwing it in, but that won't hurt any thing. my ultra holds 24 ozs but if yours is a six speed ,that might be right.
Old 05-24-2008, 05:09 PM
freebyrd's Avatar
freebyrd
freebyrd is offline
thanks big cahuna i do have the six speed so i guess i need to pick up another bottle
Old 05-24-2008, 05:15 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Shovelhead Bob is offline
The Cruise Drive transmission is checked on the side-stand....
Also, it only requires 32 oz.....
Old 05-24-2008, 09:30 PM
Skivvy9r's Avatar
Skivvy9r
Skivvy9r is offline
ORIGINAL: Shovelhead Bob
+1, and the trans dipstick rests on the threads, not screwed in.
Old 06-02-2008, 06:15 AM
roadking1893's Avatar
roadking1893
roadking1893 is offline
Just did my 5k oil changes and have a 6 speed trans. It hold 32oz. and yes rest dip stick on the thread to check. but with it holding 32oz and a quart is 32oz. If trans is completely drained you can't go wrong by pouring in a quart and be at the proper level.
Old 06-16-2008, 06:21 PM
garyhendley's Avatar
garyhendley
garyhendley is offline
#1 on what he said
Old 06-23-2008, 10:11 PM
hotshot's Avatar
hotshot
hotshot is offline
I could have sworn the manual on the '08 Ultra said to screw the dipstick in then pull out and check.&nbsp\\; I will double check that.... thanks for the info.
Old 04-24-2011, 11:23 AM
road glide o8's Avatar
road glide o8
road glide o8 is offline
does itneed to be warmed up first? i just changed on 08 road glide for first time myself...poured in qt with engine cold..... and it appears to be right about add mark?
is little hard to see cause clean now LOL should i leave like this since what book says is capacity ?
Old 04-24-2011, 11:29 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,532 Likes on 3,784 Posts
Break the plug, Straddle it straight up and make sure oil is close to full mark. No big deal. On the stand would work but slide something under stand to get bike near level (be careful). When running it probably looks like a washing machine in there anyway.
Quick Reply: how do you check transmission fluid level?
