Do the front axle require 1" bearings? I will be ordering a matching wheel for my sidecar and was told that it will require 1" bearings. I need to know if this is the same size as the front to assist with the order. I've confirmed that a 18" wheel will fit with a 130/70/18 tire.
They are 1".When Iresearched the parts books for a wheel swap a couple of months ago I compared the part numbers for '04-'06 and the bearings are the same PN--9247--and use 1" axles.
Should have mentioned that the axles, spacers, and bearings are the same for front wheels on the models mentioned in my original reply to your question.
