To magneto or not?
Old 05-18-2008, 11:28 AM
53pan's Avatar
53pan
53pan is offline
2nd Gear
Default To magneto or not?
I have a 53 pan, mostly stock, bigger cam, bigger valves and am thinking about putting a mag on. From what I can find on the internet I have about 3 choices. Joe Hunt, Morris Mag and Karata. For a cruiser would the technology of Morris and Karata be worth the cost over Joe Hunt? Any thoughts? This is going a fresh rebuild and kicker.
Old 05-21-2008, 07:27 AM
DaddyKnuck's Avatar
DaddyKnuck
DaddyKnuck is offline
Received 1,658 Likes on 943 Posts
Default RE: To magneto or not?
ORIGINAL: 53pan
This is free advice so take itfor what its worth. Mags look really cool, and you can run batteryless,but in my experience with them there are a bunch of downsides. Mostly, if they're not just right you can kick yourself silly trying to get the focker to start.
A few years back I switched to an EI distributor and wonder now why I waited so long. If you decide to go Mag, I've got a couple of primo Joe Hunts for Pan/Knuckle.
Old 05-21-2008, 02:36 PM
53pan's Avatar
53pan
53pan is offline
2nd Gear
Thanks for the info. This is my first pan, which I tore down to the frame and have back together for the most part and am trying to figure a few little things out. Your input is greatly appreciated. Thanks again!
Old 05-31-2008, 11:40 PM
stroker93's Avatar
stroker93
stroker93 is offline
I had a morris fairbanks mag for my 55 pan,,,had change of heart and went to a single fire distributor from Vulcan,,,,starts 1-2 kicks....great!
Dave
Old 06-17-2008, 05:48 AM
surv1's Avatar
surv1
surv1 is offline
I had a Joe Hunt mag on my 51 pan. Never was a problem, started 2 kicks hot or cold. It's just how you set them up. Wish I still had it.....&nbsp\\;
Rigidframe (03-26-2024)
Old 07-04-2008, 07:32 PM
mwb10's Avatar
mwb10
mwb10 is offline
Stage I
I have a morris on my 48 pan. Works like a charm. &nbsp\\;
Old 03-21-2012, 10:12 PM
o1racing03's Avatar
o1racing03
o1racing03 is offline
Dave
I know this is an old post but I have to correct the poster. The Fairbanks was a FAIRBANKS MORSE, not to be confused with a MORRIS magneto. Two differant companies.
Old 03-23-2012, 01:51 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
If you do decide to put one on, you may have to pull the front jug to get it in, you may need to remove the boss for the breaker/regulator.
I have the ebeyond 2000 sensor under my stock cover and the stock 6 volt coil.
works great.
Mike
Old 03-28-2012, 12:02 PM
Zim's Avatar
Zim
Zim is offline
Mine has been converted to 12v, but all OEM stuff and works perfectly. I agree that for a bobber or chopper the mag looks pretty cool hanging offa there, but I don't think it has an advantage over a properly dialed in stock set up.
Old 03-29-2012, 11:28 AM
o1racing03's Avatar
o1racing03
The magneto will provide a much stronger spark than a conventional set up.
SkinnyDog
10-21-2016 12:53 AM
inkdnkinkd
Custom Models
04-05-2015 05:27 PM
inkdnkinkd
EVO
03-31-2015 02:40 PM
uncle kebo
07-03-2014 09:01 PM
bastardmaker
10-25-2009 08:53 PM
Quick Reply: To magneto or not?
