difference between dyna and softail???????
Old 05-11-2008, 04:16 PM
bob37's Avatar
bob37
bob37 is offline
Default difference between dyna and softail???????
ie frame,stiffness,handling, size, etc thanks for any help
Old 05-11-2008, 05:01 PM
SK8ROD's Avatar
SK8ROD
SK8ROD is offline
Default RE: difference between dyna and softail???????
yeah Dynas are better
pete
Old 05-11-2008, 05:44 PM
ss377's Avatar
ss377
ss377 is offline
The major difference is the engine and rear shocks. Both are 96 ci. Dynas have a rubber mounted Twin Cam. Softails have a rigid mounted counterbalanced engine. Dynas rear shocks are exposed whereas the Softail are hidden giving the look of a rigid motorcycle. The ride is a little different. My dyna will shake at an idle at a stop but smooth out once it gains speed. The counterbalanced engine will run smooth at idle and vibrate a little at speed. Dynas are way better (because I got one). Sportsters ruled when I had one.
Old 05-11-2008, 05:50 PM
ConnMan's Avatar
ConnMan
ConnMan is offline
My Super Glide rides like a Cadillac.
My buddy's Softail, not-so-much.
Either is a great choice.
Old 05-11-2008, 05:53 PM
Idiot's Avatar
Idiot
Idiot is offline
Softails for show and Dynas for go
Old 05-11-2008, 05:56 PM
bob37's Avatar
bob37
bob37 is offline
any technical infe such as frame dimensions which is talleer,longer etc?
Old 05-11-2008, 06:01 PM
Idiot's Avatar
Idiot
Idiot is offline
ORIGINAL: bob37
I don't know the specs, go to the Harley-Davidson website and you can compare specs side by side. Generally speaking, the Dynais the lightest bike fitted with the "Big V-Twin" engine which a lot of Dyna riders will tell you affords them better handling and a more nimble ride.
Old 05-11-2008, 06:02 PM
jbphoto's Avatar
jbphoto
jbphoto is offline
ORIGINAL: bob37
Go here and click on Dyna. Click on any model and you can compare models under tools (middle left)
http://www.harley-davidson.com/wcm/C...p?locale=en_US
Old 05-11-2008, 06:03 PM
ClarkFXDC's Avatar
ClarkFXDC
ClarkFXDC is offline
They don't call them "sloptails" for nothing.
Old 05-11-2008, 06:41 PM
RKLeo's Avatar
RKLeo
RKLeo is offline
Dynas have great suspension........Softails bottom out a lot.
Quick Reply: difference between dyna and softail???????
