2006 Night Train Swing Arm
RE: 2006 Night Train Swing Arm
I never tried it but may have someone willing to try it . I bought the stock denum blue set (tank and fenders ) that I was planning on putting custom paint on but never got around to doing . My friend was thinking of putting it on his 02 softail and he would need that swingarm and wheel . Would you sell anything else or just the swingarm ?
The '06-up 200 tire swingarms are the same width/size as the '05 and lower HD's...theonly difference is in the brake caliper mount (it sets the brake caliperfurther out to compensate for the wider rim/brake rotor)...the swingarm should fit the earlier softails ('99 and below I'm not sosure about)
ORIGINAL: 06kustom
Did any of you installed the stock swingarm that came with the 200mm tire on any other softail? Just need to know this because I plan to sell it after I install my 250 kit. Please let me know..Thanks
ORIGINAL: Loud1
Thanks FXSTI GUY,
So your saying that if someone wants to buy the swingarm they'll need to also get a brake caliper that fits 06-up models besides the 1" pulley.The 06 frameare slightly wider on the mounting holes. Do you need to any modificationon the belt sideof the trans and or need to offset anything else? If you have any more info it would be greatly appreciatated. Save the on the headaches.
THANKS..
DarrelRodman
10-28-2022 01:01 PM
