Need Help installing a screaming eagle ignition
Old 04-20-2008, 02:17 AM
Jhay's Avatar
Jhay
Jhay is offline
Stage II
Default Need Help installing a screaming eagle ignition
Hey Guy's... i have just bought a screaming eagle ignition to allow the bike to rev to 8000 rpm...
i have plugged it in but the bike won't run... Does anyone know the sequence to get it working ???
Old 04-20-2008, 02:29 AM
6o66er's Avatar
6o66er
6o66er is offline
Default RE: Need Help installing a screaming eagle ignition
It should time about the same as your stock module. The install instructions here: http://mysite.wanadoo-members.co.uk/...ns/_j01964.pdf
are for BT models, but they should be about the same for a Sportster.
You can install the module with a SM, they were designed to be installed and work with your factory setup, unlike aftermarket standalone units like Crane Hi-4's, etc.
Is it firing at all? We'd need symptoms of what it's been doing to accurately help you out.
Old 04-20-2008, 03:42 AM
cHarley's Avatar
cHarley
cHarley is offline
Several people here who have had trouble getting the module to work using the HD instructions have reported sucess using these SE instructions from NRHS: http://www.nrhsperformance.com/tech_xllearn.shtml
I guess the sequence is a little clearer.
Good Luck
Old 04-20-2008, 03:48 AM
6o66er's Avatar
6o66er
6o66er is offline
...Ah...had to check his profile to get the year of his bike. That sounds like a ROYAL pain in the ***...good luck.
Old 04-20-2008, 04:07 AM
cHarley's Avatar
cHarley
cHarley is offline
Yea, it makes it a bit hard to answer technical questions when they don't give you any info of the year & model of the bike.[:-]
Guess it's time to run the "Topless" post again from a couple of months ago.
Old 04-20-2008, 08:17 AM
aceospades's Avatar
aceospades
aceospades is offline
i used the same instructions that charley posted..better make sure you have a battery charger hooked up during the process..
Old 04-20-2008, 08:25 AM
cootertwo's Avatar
cootertwo
cootertwo is offline
He also should have a basket, to put the pieces in, when he reaches 8000 rpm...............
Old 04-20-2008, 08:27 AM
SpursDarkrider's Avatar
SpursDarkrider
SpursDarkrider is offline
Can anyone clarify the turn ignition switch on-off inside of 2 seconds after waiting 10 minutes while its learning-entering password? Do you have to time the 10 minutes?
Old 04-20-2008, 08:28 AM
aceospades's Avatar
aceospades
ORIGINAL: cootertwo
lol, mine is a 7,000 rpm module,i havent hit the rev limiter since i put it on..and i dont plan on it
Old 04-20-2008, 11:39 AM
jpar05nm's Avatar
jpar05nm
jpar05nm is offline
I have the 7000rpm module in mine. Had to take it to the dealership and have the bike and module formally introduced through their computer.
Quick Reply: Need Help installing a screaming eagle ignition
