Sissy bar install
Old 04-13-2008, 01:34 PM
Crazy2sin's Avatar
Crazy2sin
Crazy2sin is offline
Default Sissy bar install
Boy was this fun! Decided to go rigid to make it a lil cheaper. Right side sideplate when on no problem. Left side was a different story. Went to unbolt the turn signal nut and it unscrewed from the turnsignal itself, leaving the bolt and nut still inside the fender lol. Ended up having to take the cover off to see the nut that is attached in the middle of the bolt. But to do so i ended up having to cut the wire to the signal. Was running late to my brothers bday party since i didnt see it taking more then 20 min to unbolt and slide these in. So i bolted everything back on, boy was the signal a pain to get back attached, without the signal wired up. Ended up taking it back apart this morning and rewiring the signal. So what i thought was gonna be 20 min ended up taking me an hour and a half. But its always more fun installing things yourself if u can.
Old 04-13-2008, 01:39 PM
SportyPig's Avatar
SportyPig
SportyPig is offline
Default RE: Sissy bar install
Unless you have the bike on a jack or lift, that left side can be a royal pain to work on.
Old 04-13-2008, 11:05 PM
joel85's Avatar
joel85
joel85 is offline
My left bolt did the exact same thing! Turn signal came apart into pieces lol, I did not cut anything though ended up getting it all re assembled. I just unhooked the wire from the brackets inside the wheel well and it gave me enough extra length. I also did not have a jack. Looks good now though.
Old 04-14-2008, 08:46 AM
Nick's Avatar
Nick
Nick is offline
the right side gave me grief
HotRodNut
01-09-2017 09:16 AM
95harleygal
Electrical/Lighting/Alarm
07-09-2013 07:13 AM
love2ride71
07-23-2010 01:11 AM
pr_capone
08-28-2008 12:24 PM
oldie
10-19-2006 06:34 PM
Quick Reply: Sissy bar install
