Cruise control not working - Weird fix
Old 03-29-2008, 08:15 PM
Bluerose
Guest
Posts: n/a
Default Cruise control not working - Weird fix
So I took the scoot out for a ride today to really get a feel for the new bars. Everything was going well until I got up on the freeway and decided I'd hit the cruise control for the few miles we would be on it.I flipped the cruise switch and hit "Set". Nothing happened...Uh Oh.
Got home and Hubby pulled out the Electrical book. He was sure he took great care with putting back the wires and verifying the connections. Was not at all excited with the prospect of pulling the fairing back off.
Turns out because we had the battery disconnected there was a needed reset. You had to reset, of all things, the security pin? I reset the security pin tried the diagnostic and all was well.
Thought that was a strange one I might share [&:]
Old 03-29-2008, 08:32 PM
sewerat's Avatar
sewerat
sewerat is offline
Default RE: Cruise control not working - Weird fix
You see just one more thing that was changed in 08 I have never heard of having to reset all the security pins before? Did your fabs works?
Old 03-29-2008, 09:07 PM
Bluerose
Guest
Posts: n/a
ORIGINAL: sewerat
The funny thing was the security pin was correct. I just had to step through pin...I didn't change a thing.
fabs? Everything else was workin just fine.
Old 03-29-2008, 09:31 PM
ironhead3fan's Avatar
ironhead3fan
ironhead3fan is offline
That is really weird. Thanks for sharing. Someone will be searching for this one day.
Old 03-29-2008, 10:52 PM
Bluerose
Guest
Posts: n/a
ORIGINAL: ironhead3fan
Thats what I figured...never would have thought......
Old 03-29-2008, 10:56 PM
Jim Dawson's Avatar
Jim Dawson
Jim Dawson is offline
Hmm, I've disconnected the battery several times and I didn't have to reset anything. I guess I was lucky for once. I'm glad you figured it out, now I hope I remember what you did the first time it happens to me.
Thanks for the info.
Old 03-29-2008, 10:57 PM
iclick's Avatar
iclick
iclick is offline
ORIGINAL: Bluerose
You must perform a "reset" every time you disconnect the battery?
Old 03-29-2008, 11:10 PM
Bluerose
Guest
Posts: n/a
ORIGINAL: iclick
ORIGINAL: Bluerose
Only if it does not work I would guess....we did a lot to the bike including dis connecting the control wires for an extended period.
cwickgo9
2014-2023 Touring Models
09-15-2017 02:00 PM
captjag
03-29-2017 01:47 PM
dhweber1
07-18-2016 02:35 PM
commander112
04-27-2011 03:30 PM
rhaneski
06-29-2009 06:15 PM
Quick Reply: Cruise control not working - Weird fix
