fuel injection 1998 roadking
Old 03-29-2008, 10:09 AM
ridetodrift's Avatar
ridetodrift
ridetodrift is offline
Stage III
Default fuel injection 1998 roadking
I repainted my bike this winter and now that it is reassembled the fuel pump does not run when I
hit the run switch, it appears the computer comes to life, I have spark and it will run if I squirt gas down the cylinders
THe wire under the dash gets 12.5 volts for about two seconds then it goes dead..the fuel gauge lights and it appears to work.I just
can not hear the pump run...Any Ideas?
Old 03-29-2008, 01:58 PM
Doc 1's Avatar
Doc 1
Doc 1 is offline
Default RE: fuel injection 1998 roadking
Look at the connector on the gas tank, there are three spade connectors in side...make sure you didn't bend one of the spades while pushing on the wire harness connector.....if yo udid straighten it up and reconnect it carefully, the pump will work now.
Shane T
05-17-2017 08:26 AM
wborden
05-06-2014 01:59 AM
texrdglide
08-14-2008 05:48 PM
ridetodrift
03-29-2008 10:41 AM
Longhauler
07-09-2007 08:50 PM
Quick Reply: fuel injection 1998 roadking
