Fork oil weight
Old 03-27-2008, 12:28 PM
arnold's Avatar
arnold
arnold is offline
Default Fork oil weight
Can someone tell me the actal wt of HD and screaming eagle fork oils? The bottles all just say..E etcc, or "heavy duty" I would like to know the actual weights.
TIA
Old 03-27-2008, 02:34 PM
donk_316's Avatar
donk_316
donk_316 is offline
Default RE: Fork oil weight
Holy Moly! A search found the answer?? Imagine that!!
https://www.hdforums.com/m_2553876/tm.htm
Old 03-27-2008, 03:37 PM
arnold's Avatar
arnold
arnold is offline
Holy Moly! I didnt feel like searching?? Imagine that!!
Thanks
Old 03-27-2008, 03:59 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
As you can see from that search......nobody really knows.....
Old 03-27-2008, 04:12 PM
lecomte38's Avatar
lecomte38
lecomte38 is offline
Hey - thats my thread. I never did get an answer but I went with 50/50 mix of SE and type B
Works fine on my 02 flhr
Old 03-28-2008, 12:15 AM
arnold's Avatar
arnold
arnold is offline
Fork Oil - 16oz. Type E 5wt. Type E is for "Showa" forks.Part # 99884-80
Fork Oil - 16oz. Type B 10w. Fork Oil - See owners manual for recommended style. Part # 99880-73
Screamin’ Eagle® Performance Fork Oil - A heavier oil (15wt) provides extra damping in performance application. Part # 99881-87 . Works well to take the dive out of the front end on breaking.
Screamin’ Eagle® Racing Fork Oil - Designed and blended for the severe conditions on the race track (20wt). Not intended for street use.
Part # 99909-93R
Stole from another forum
Old 03-28-2008, 03:07 AM
bklynbob's Avatar
bklynbob
bklynbob is offline
Default RE: Fork oil weight more info for ya
I use race-tec us-3, it's 15wt... 01 fxd... rac-tec springs,I'm 200lbs 30% 2 up....not a soft ride but not as stiff as as screamin eagle fluid.Ive also used amsoil medium in the past,it's a slightly smoother ride.I believe my forks call for 1.6 oz.i always round it to 11 oz.I slowly work the forks to get the air out and then check that each is leg is the same level.
Old 03-28-2008, 07:52 AM
twiceretired's Avatar
twiceretired
twiceretired is offline
I used the SE heavy fork oil when I changed to Progressive springs in my Deuce. Feel like it's too heavy, and intend to drop down just a bit.
Old 03-28-2008, 10:33 PM
donk_316's Avatar
donk_316
donk_316 is offline
need alot more info to make any of this "i use xxx oil" usefull.
What bikes and how much do you weigh? 1up?2up? luggage?
Old 03-28-2008, 11:58 PM
arnold's Avatar
arnold
arnold is offline
I just changed mine today. I had (at least this is what HD told me), E 5wt.
I changed to Screaming Eagle Performance Fork Oil heavy (not to be used for street WTF?).
I weigh 183
I pack the ole lady around a lot, she's been riding behind me for most of 20 yrs.
I Have bags, full or MT depending.
I plan a 2 1/2 grand or so trip in june, I will add on whatever I can find a spot for, T bag as well.
I dont know what that 'not for street use' **** is, Bob handles and corners GREAT by comparison to that 5 wt **** that was in there.
Quick Reply: Fork oil weight
