Radio Display Screen BLANK!
Old 03-24-2008, 08:41 AM
Harleynole's Avatar
Harleynole
Harleynole is offline
Default Radio Display Screen BLANK!
Went out Sunday morning to take the scoot for a ride. Got on, started her up and my radio display screen is blank. Nothing, nada....however everything still works fine with the hand controls, CD, radio, volume, etc.
No clock, no nothing.
What's up with this??
Old 03-24-2008, 09:04 AM
stro1965's Avatar
stro1965
stro1965 is offline
Default RE: Radio Display Screen BLANK!
You might try pulling the radio fuses (I think there are 2 of them) for a minute and see if that resets everything.
Old 03-24-2008, 10:37 AM
Capt.Bob's Avatar
Capt.Bob
Capt.Bob is offline
Mine did that one time. I turned it off with the ignition switch still on and turned it back on again. Everything was cool again.
Old 03-24-2008, 10:56 AM
Doug45601's Avatar
Doug45601
Doug45601 is offline
Computer glitch... When initializing, the software registary jumped over the command to show display.. reflash your radio... download from Harley.com
Old 03-24-2008, 11:04 AM
Windup08's Avatar
Windup08
Windup08 is offline
ORIGINAL: Doug45601
You mean Harley's run Microsoft Windows?....
Old 03-24-2008, 11:05 AM
big_al's Avatar
big_al
big_al is offline
ORIGINAL: Harleynole
The same exact thing happened to my 06 and the radio had to be replaced and to top it off it was out of warranty and thank god that the service mgr did a goodwill replacement for me..
Old 03-24-2008, 11:06 AM
cfmii11's Avatar
cfmii11
cfmii11 is offline
Check the contrast, if you hit the adjustment by mistake it will go blank.
Charlie
Old 03-24-2008, 11:17 AM
avcaruso's Avatar
avcaruso
avcaruso is offline
Received 1,315 Likes on 176 Posts
Not sure what year your bike is, but the HK on my 2006 EGC did the same thing and needed to be replaced. Dealer tried to do a software update first but it did not work. I did a lot of research on this when mine went south, and many have to be replaced. Do a search here and you will find a ton of info.
panheadscooty
Audio Systems
10-19-2015 11:06 AM
ny2az
Touring Parts
10-13-2012 06:34 PM
ltmdl90
Audio Systems
06-23-2011 11:50 AM
RANDIT
06-14-2008 10:52 PM
Quick Reply: Radio Display Screen BLANK!
