Is Handlebar triple tree ground strap necessary?
Old 03-22-2008, 03:49 PM
Dynamite17's Avatar
Dynamite17
Dynamite17 is offline
Default Is Handlebar triple tree ground strap necessary?
I installed the poly riser bushings today and all went well until I tightened up the right side with the ground wire that connects the riser bolt to the triple tree, I assume to provide a ground path to the the handlebars. The star lock washer was turning as I tightened the bolt, and my attempt to stop it from turning busted it. I made a new one but wonder if it's really necessary. I doubt MoCo would spend even $1 to install something unnecessary though.
Does anything get it's ground path through the frame, I hope not.
Put on the Gerbings heated gloves and put on 30 miles in 37-40 degrees. Nice.
B
PS. Not sure I detect any difference in the feel, but had heavy hot gloves on.
Old 03-22-2008, 03:56 PM
lee's Avatar
lee
lee is offline
Default RE: Is Handlebar triple tree ground strap necessary?
yes i think you need it when i was playing around changing bars /clocks various things my alarm started giving me trouble but stopped once i re-attached earth to triple trees
cheers lee
Old 03-22-2008, 04:01 PM
CHEESE's Avatar
CHEESE
CHEESE is offline
Mine broke when I changed risers two years ago. I meant to fix it, I still might someday, but it hasn't seemed to make any difference at all.
Old 03-22-2008, 04:28 PM
DougsDyna's Avatar
DougsDyna
DougsDyna is offline
ORIGINAL: CHEESE
Me too, I'v been meaning to get around to it, though...............
I think it's part of the lightening arrester circuit.
DougJ
Old 03-22-2008, 04:45 PM
mattia's Avatar
mattia
mattia is offline
What wire
Old 03-22-2008, 07:36 PM
glide05's Avatar
glide05
glide05 is offline
probably dictated by the DOT.
without it - your bars are "floating" relative to the rest of the bike.
off hand - I can't think of how this would cause a problem - unless some type of switch attached to the bars used them as a a return to battery negative.
nothin in the stock switching is configured this way - maybe an aftermarket switch - but no issues with stock.
i think if you get struck by lightning - you're pretty much f'd anyway!
Old 03-23-2008, 06:19 AM
ShoreRider's Avatar
ShoreRider
ShoreRider is online now
ORIGINAL: glide05
2nd your logic on the potential for floating, but don't see that happening. I f-ed up my wire 9 months ago and haven't had it on since with no problems. This includes changing out the headlight which uses the triple tree as the ground source. If the bars/forks were floating, then the light wouldn't have worked. So much for proofing that the ground strap is required. It more than likely is as you say, a secondary ground path to meet DOT requirements.
Old 03-23-2008, 06:34 AM
DougsDyna's Avatar
DougsDyna
I am sure it's precautionary, just in case. Probably of no value 99.999999% of the time. I guess we all would wish it was there when the headlight suddenly quit working on a nigh ride and no moonlight.
DougJ
Old 03-23-2008, 09:22 AM
Dynamite17's Avatar
Dynamite17
Could someone without the ground wire use an ohm-meter to see if the frame to handlebars are electrically connected with close to 0 ohms?
Old 03-23-2008, 09:57 AM
rbabos's Avatar
rbabos
rbabos is offline
While you can get a ground from the head bearings, clutch cable and throttle cables it is not an accepted practice to do so. A seperate ground is the best method to eliminate these other sources of ground that could at times become intermittant.
Ron
Quick Reply: Is Handlebar triple tree ground strap necessary?
