06 streetbob triple tree nut size?
Old 03-15-2008, 08:49 PM
jackyl's Avatar
jackyl
jackyl is offline
Default 06 streetbob triple tree nut size?
iam in the process of changing my triple trees on a 06 streetbob to wdg trees. what is the triple tree nut size? is it 1-1/2? thanks jackyl
Old 03-15-2008, 08:57 PM
fiend138's Avatar
fiend138
fiend138 is offline
Default RE: 06 streetbob triple tree nut size?
My 08 is 1.5"
Old 03-15-2008, 09:04 PM
DynaDan's Avatar
DynaDan
DynaDan is offline
Jackyl,
If you are talking about the steering stem nut it is defintely 1 1/2" I took mine off the other day to swap out the washer for the new one to fix the clunk. It actually worked too.
Old 03-15-2008, 09:10 PM
jackyl's Avatar
jackyl
jackyl is offline
i had a feeling it was the 1-1/2 for the stem nut. because ihad a 1-1/4 and it looked like two sizes up [:@][:@][:@]. will have to wait til monday to get it at work. thanks guys jackyl
Old 03-16-2008, 04:02 AM
jmpancoast's Avatar
jmpancoast
jmpancoast is offline
Jackyl, I just picked up a five piece Craftsman socket set, 1" through1 1/2", 1/2" drive from Sears on sale for $19.95. Don't know if the sale is still going on.
Old 03-16-2008, 06:34 AM
deeblues's Avatar
deeblues
deeblues is offline
Hey Jackyl.......what are you gonna run for a front wheel after you go to the wide glide trees???
If your gonna use your stock 19 inch where did you find a decent priced hub spacer??....
I'm still sitting on my wide glide trees and axle.....
I might just stay with the narrow glide and give up the OEM trees from HD....
My 07 with a 2 inch Jackyl lift.....
[IMG]local://upfiles/23685/D43A0F9C76FE4B2C903142D4EC5A7F9E.jpg[/IMG]
Old 03-16-2008, 08:37 AM
jackyl's Avatar
jackyl
jackyl is offline
ORIGINAL: deeblues
iam going to be using a 21 rim. you can find a wdg hub for a decent price on ebay, if your going to be running your 19 stock rim. they range from $60-$80 make sure you get one for 80 spokes if your using the stock rim. jackyl
nkauf21
01-18-2012 03:45 PM
tjg4036
10-06-2010 08:31 AM
streetbobkid
02-18-2010 07:08 PM
davidc
04-19-2009 06:43 PM
Motosurf
04-27-2007 04:06 AM
Quick Reply: 06 streetbob triple tree nut size?
