fairing removal on 95 electra glide
Old 03-15-2008, 07:45 AM
J.J.'s Avatar
J.J.
J.J. is offline
Default fairing removal on 95 electra glide
I want to take the fairing off my 95 electra glide so I can change out the speakers. Any guidance would surely be appreciated. I also want to change out the back ones but when I look at the speaker covers I see no screws anywhere to remove them.....any thoughts on this would be appreciated as well......thanks in advance
Old 03-15-2008, 08:07 AM
kyote's Avatar
kyote
kyote is offline
Default RE: fairing removal on 95 electra glide
Just changed the fairing speakers on mine.. Easy to do..
1. Take off Chrome headlight trim ring. ( one screw on bottom...) you will have to tug it a bit..it is on there pretty snug...
2. Remove 4 screws that hold headlight assembly... unplug headlight..
3. Unbolt fairing...inside there are 4 bolts.. a speedwrench works wonders to take off the nuts....
4. Remove the 5 windshield bolts & nuts....
5. Pull fairing off... swap speakers.. ( mine only had 3 screws holding them in...)
6. Put it all back together..........
Old 03-15-2008, 08:25 AM
Lpye's Avatar
Lpye
Lpye is offline
You also have to take the bolt out of the spot lights and set them down. Place a towel on the front fender andlet them rest on it.
Old 03-15-2008, 08:27 AM
kyote's Avatar
kyote
kyote is offline
OOps.. yeah forgot that part.....
Old 03-15-2008, 09:30 AM
J.J.'s Avatar
J.J.
J.J. is offline
Thanks much for the info.......
Old 03-15-2008, 10:58 AM
hamnhog's Avatar
hamnhog
hamnhog is offline
I have a '96 UC that's same as yours. Just remove the outer fairing:
Take out the four screws from the winshield trim strip and remove the winshield before it falls out and gets sctartched (don't ask me how I know).
Remove the 4 screws from the inner fairing that hold the 2 fairing halves together. I think these are size 27 Torx heads.
Lift the outer fairing carefully forward and unplug the headlight connector.
Lift the outer fairing up and away from the bike.
Finding suitable speakers that fit may be something of an issue. Pez says an adaper is needed for his speakers. I haven't tried to locate any but it sounds like it might not be quite as simple as going to Wally World and grabbing a set. I also have not found the secret to removing the rear speaker pods. The last of the Evo tourers seem to be a little different to do anything to than the TC models. Good luck.
Old 03-15-2008, 02:16 PM
J.J.'s Avatar
J.J.
J.J. is offline
ORIGINAL: hamnhog
Thanks for the info.......could you give me an idea where those 4 screws might be located.....along the edges or top and bottom and how difficult are they to get to.......I got the speakers from J&M and they are supposedly the right speakers for the year and make of the bike. I'll keep digging on those rear speakers.......Maybe have to go in through the trunk....I think there are screws going into the trunk from the speaker pods.....we'll see.....
Old 10-14-2012, 12:48 PM
WVRave's Avatar
WVRave
WVRave is offline
Stage I
IS it possible to just remove the speaker grill covers, without removing the faring?
Thanks
Old 10-14-2012, 01:42 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
Originally Posted by hamnhog
I have a '96 UC that's same as yours. .
the 96 fairing is different than the '95.
good advice in the earlier post.
when loosening the 4 fairing support bolts, not the location of the washers- if the fenders washers are dished or warped, replace them.
also the windscreen has the 2 lower bolts as well so a total of 7 bolts for the windscreen. an extra set of hands is helpful when doing this operation.
the chrome strip which holds the windscreen bolts can scratch so mask the area with tape, coming off and going back on.
if the clips on the bolts are loose, any auto parts store will have suitable replacements
the 95 fairing was such a pain to remove that I kept a list of the stuff I wanted to do inside the fairing- so that I could do a bunch of stuff at once, such as:
headphone jack wired into stereo
relay packs for the headlight hi/lo and spots ( wiring into the battery to take the load off the ign switch)
change out inst. bulbs for new
etc
mike
hdbob2006 (03-27-2021)
Old 10-14-2012, 01:43 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
Thanks
no.
the 1995 and earlier is fiddly
the 1996 and up is pretty easy
mike
Quick Reply: fairing removal on 95 electra glide
