The FXDL Idiot Light relocation part
Old 02-05-2008, 07:04 PM
hedquistk's Avatar
hedquistk
hedquistk is offline
Default The FXDL Idiot Light relocation part
I have seen a lot of posts asking about idiot light relocation with FXDL. I found this part the other night and I hope this helps. Looks like someone is looking out for us old school guys.
As far as drilling the 3/8 hole into the triple tree:
From what I have read there is no integrity issues doing this. Is that the case? Or has anyone had any issues? My question is the bolt on the other the other end what type should I use so I dont see it?
[IMG]local://upfiles/52493/C7981B3BDFC54D5FBE8E511E09738F4D.jpg[/IMG]
Old 02-05-2008, 07:49 PM
rowan's Avatar
rowan
rowan is offline
Default RE: The FXDL Idiot Light relocation part
can you provide some additional info on the particularsto that part you posted.
were it was found etc.
Thanks
carl
05 FXDLI
Old 02-05-2008, 07:57 PM
hedquistk's Avatar
hedquistk
http://www.headwinds.com/mm5/merchan...;Category_Code=
Should get you to where you need to be if not, go to www.headwinds.com find the search tab at the top and paste this in:
INSTRUMENT PANEL, FXL, FXD, XLH WITH INDICATOR PANEL SLOT
I think I am going to order one when I mount a a billet style light.
Cheers,
Guns
Old 02-05-2008, 10:43 PM
20LowRider02's Avatar
20LowRider02
20LowRider02 is offline
NICE FIND!!! For $37 I won't have to beat my head in trying to make my own now!!
Old 02-09-2008, 04:30 AM
jwidell's Avatar
jwidell
jwidell is offline
I just posted under "Dyna Glide Models" the same question about this relocation, and then found this. Thanks! Can you tell me how this is mounted? I want to change out the handlebars for mini apes, and also the headlight.
Again, GOOD FIND!
Jack
Old 02-09-2008, 06:08 AM
rjmac53's Avatar
rjmac53
rjmac53 is offline
Gotta luv this place !!!
Old 02-09-2008, 06:27 AM
jwidell's Avatar
jwidell
jwidell is offline
I joined this forum last year, and forgot all about it. I also found what I needed to replace my stock handlebars with mini apes as on the Street Bob. Sure beats going to the dealer and asking questions that they don't care to answer!
Old 02-09-2008, 10:12 AM
Halfbuck's Avatar
Halfbuck
Halfbuck is offline
Here's the text from a post that I made a couple of years ago. The info might still apply. I had contacted Headwinds about changing out my headlight and indicator lights mount:
___________________
I'm planning on switching to mini apes on my 05 Low Rider and thought it might be a better looking set-up if I could do away with my headlight visor. Problem is, I'd have to relocate my indicator lights (which are in the visor) and would also have to come-up with another headlight mount since it is top-mounted into the visor.
In case anyone else is interested I received the following info from a company called Headwinds (www.headwinds.com). Looks like it would cost approx. $90 in parts plus a headlight .....
***Info From Email Response From Headwinds***
This is for the XLH, FXR, FXD bikes with top mounted headlights.
The first option would be to remove the visor that the stock headlight currently mounts too. The first thing you would have to do is drill a 3/8" hole into the bottom of your lower tree. Then you can take one of our mounting blocks, bolt it to the bottom tree and then you can mount any 5 3/4" Headwinds headlights on your bike. Once you have done that, we also made a instrument panel that replaces the visor so you can still mount your indicator lights.
Part number list for above setup:
1-0021XLH - Mounting block for 5 3/4" bullet housings.
1-0002 - Mounting block for 5 3/4" rocket housings.
100-0009-125 - Bolt kit, lower tree to mounting block.
100-0001A - Bolt kit, headlight to mount.
6-0005 - Instrument panel for mounting indicator lights.
Old 02-09-2008, 10:37 AM
JRK5892's Avatar
JRK5892
JRK5892 is offline
guys you can relocate the Idiot lights with about 5 dollars in parts from radio shack... i just put idiot lights on my LR dash i put on my bob they are over and under the main bolts that support the dash... works great just takes some solder time and patients!
Old 02-10-2008, 05:25 AM
dazza's Avatar
dazza
dazza is offline
no longer have that problem or the ignition with the wide glide conversion on my 07 FXDL
Quick Reply: The FXDL Idiot Light relocation part
