how to change front &rear brake pads
RE: how to change front &rear brake pads
no you dont have to machine them when the wear you just replace them .i just put new floating rotors on and are changing my stock pads to the lyndall z pads.everyone saysthey do not wear out your rotors and they throw off minimal brake dust. this will be a big help in keepingmy white wall tires clean.IM HOPPING THEY ARE RIGHT.
ORIGINAL: jokr
What brand floating rotor did you get and where did you get it. Thanks for your help...
ORIGINAL: jokr
ORIGINAL: jokr
DO YOU KNOW IF IT WILL DIS COLOR THE WHITE THANKS FOR YOUR INPUT FAST CHARLIE
[IMG]local://upfiles/29413/92A9696879CB42508998916891DF29C1.jpg[/IMG]
I just changed my rears tonight and it was a snap. just had to go to the store and buy a 1/4" wrench that had a thinner wall since mine was too thick to slide all the way on the pin. Just take your time and have fun... The instructions that came with the set were the same as the ones in my manual. First brake job on my first harley, no problem... I didn't use locktite since I didn't want to take a chance of stripping the heads on the little quarter inch twelve sided bolt. I simply tourqed it as hard as that little tiny wrench could tighten it. Figured the brake dust will lock her up. Plus I will keep a watchfull eye on it as I am a worry wart by nature...
ORIGINAL: conroskie
what on earth are those strange looking things behind your bike???[sm=chattypair.gif]
