Pocketscan OBDII
Old 01-26-2008, 06:08 PM
HB's Avatar
HB
HB is offline
Default Pocketscan OBDII
I was told that you could pull codes with a pocket scan obd2 reader. Does anyone know about this and how to hook it up. I have used the jumper like they tell you on the tech tips. I would rather use a scanner as it would be easier and would also be able to erase any codes I may have. I don't know if you can just plug it into a portion of the scanner or if I was misled. The plug on the scanner is a whole lot wider than the hookup on the bike.
Old 01-26-2008, 06:39 PM
Lamar07's Avatar
Lamar07
Lamar07 is offline
Default RE: Pocketscan OBDII
scanner wont hook to a harley
Old 01-26-2008, 06:48 PM
1Harleyrdr's Avatar
1Harleyrdr
1Harleyrdr is offline
I just got a magazine with instructions on how to do this. I will try to remember which magazine had this in it. It works on the bikes with electronic odometer I believe. Can someone help me out to which rag
Old 01-26-2008, 08:37 PM
TXCHOP's Avatar
TXCHOP
TXCHOP is offline
http://www.daytona-sensors.com/Twin_Scan2.html
This is a good as you are going to get. I have one, works great and pretty cheap.
Fatboy931
EVO
28
11-29-2022 11:22 AM
echo74922
06-04-2014 11:15 AM
CGLTD
09-16-2008 08:32 PM
eriesportster
Exhaust System Topics
11-27-2006 11:49 PM
Shovelhead77
02-26-2006 03:15 PM
Quick Reply: Pocketscan OBDII
