Synthetic oil for '81 shovelhead?
Old 01-21-2008, 07:37 PM
lowglide81's Avatar
lowglide81
lowglide81 is offline
Default Synthetic oil for '81 shovelhead?
I purchased a 1981 FLHC last fall. The previous owner had 15000km on a rebuilt engine and was using Penzoil 20W50 engine oil. I have drained the oil and have a new oil filter to install. I am looking for advice on wheather or not I am safe to try a synthetic oil such as Mobil 1 V-twin 20W50 in this shovelhead engine?
I apreciate any insight on this subject!
Old 01-21-2008, 08:01 PM
bear95252's Avatar
bear95252
bear95252 is offline
Default RE: Synthetic oil for '81 shovelhead?
Here is a link to what AMSOIL recommends.... http://www.amsoil.com/products/stree...oil_chart.aspx
Bear
Old 01-21-2008, 08:28 PM
customsoftail200's Avatar
customsoftail200
customsoftail200 is offline
You can get Amsoil right here!!!
lowglide81's Avatar
lowglide81
Thank you for the link Bear!
Anyone switched from conventional oil to Amsoil SAE 60 Synthetic Racing Oil (AHR) in a shovelhead with improved results? or does it make that much of a difference?
Old 01-21-2008, 09:53 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
I would not use synthetic oil in that engine unless you are certain the gaskets are all the same materials technology used after 1995. ( which I doubt). The materials technology used back then is questionable with regard to compatibility with syn oils. It might work fine but you could get leaking issues that are a PITA to repair and costly as well. If that bike isn't leaking your best sticking with conventional HD360 20w50. JMHO. You can also use Bel-Ray 85w140 in the trans as that is dino as well.
Old 01-21-2008, 10:04 PM
lowglide81's Avatar
lowglide81
Thank you JMHO, that is the knowledgeable input I was looking for.
greatly apreciated!
Hardater 81 Sturgis
04-24-2018 08:36 AM
Jkar1983
20
05-17-2013 04:09 AM
SweedTownHD
02-15-2012 03:48 PM
Timboto
08-28-2007 07:07 PM
Timboto
Shovelhead
08-27-2007 12:34 PM
Quick Reply: Synthetic oil for '81 shovelhead?
