Fork Stem Cap Removal (FXDWG)
Old 01-13-2008, 12:58 PM
friknjok's Avatar
friknjok
friknjok is offline
Default Fork Stem Cap Removal (FXDWG)
How do you removethe front fork stem cap?
I'm baffled, and the service manual is no help. I'm tryingto access the adjuster nut to correct the front end "fall away."
Thanks.
Old 01-13-2008, 01:17 PM
impala's Avatar
impala
impala is offline
Default RE: Fork Stem Cap Removal (FXDWG)
if you are talking about the cap on top of the upper tripple tree, and just under the handle bar, and about 1.5 inch across, than
it just unscrews. there is like a 1/4 20 bolt welded in the center going straight down. and the cap is like a small paint can top.
to take off just unscrew like any bolt. you may need a strap wrench or slip joint pliers with something that wont scratch like an old leather belt.
found this out when the dealer left mine loose after not fixing the noise.
Old 01-13-2008, 01:24 PM
Baeseman1's Avatar
Baeseman1
Baeseman1 is offline
That gave me troubles for a few minutes also... Sometimes the simplesolution isn't so obvious...
Old 05-19-2010, 02:13 PM
maddghost's Avatar
maddghost
maddghost is offline
Ya see ! thanks boyz I need to adjust my fall away and found this post with the search function!!!
Old 05-19-2010, 02:51 PM
jto667's Avatar
jto667
jto667 is offline
Is this the same cap where you replace the washer to get rid of the front end "clunk"? Thats next on my to do list.
Old 05-19-2010, 05:49 PM
Y2KFXDman's Avatar
Y2KFXDman
Y2KFXDman is offline
Originally Posted by impala
... to take off just unscrew like any bolt. you may need a strap wrench or slip joint pliers with something that wont scratch like an old leather belt...
You can improvise with an appropriate size hose clamp; don't forget leather or rubber to protect the finish.
Old 01-09-2011, 09:41 PM
Vins's Avatar
Vins
Vins is offline
Who knew? Was trying to figure it out how to get the cap off and accidentally did. Looked all over the internet and couldn't find anything. The parts catalog and maintenance manual do not show this or describe it. Should have searched "stem cap removal" to begin with. Was looking at "triple tree removal". Oh...and used duct tape. Wasn't that tight.
Old 01-10-2011, 01:50 AM
PKellyMc's Avatar
PKellyMc
PKellyMc is offline
Location: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Yepper, got stumped by this one, too. Gripped mine real tight and gave it a twist...waa-LA!
Old 01-10-2011, 05:12 AM
mang0's Avatar
mang0
mang0 is offline
used one of those rubber grip things (like you use to open stubburn pickle jars)--found it in the kitchen utensil drawer, now its in my tool chest ;-)
MMH
03-18-2019 06:59 PM
BULA
08-25-2018 08:35 AM
flynavy
02-26-2011 08:12 PM
friknjok
01-13-2008 02:26 PM
jjc1
10-09-2006 12:52 AM
Quick Reply: Fork Stem Cap Removal (FXDWG)
