will this Avon tire fit the deuce rim, instead of the dunlop 180
Old 01-12-2008, 04:15 PM
jackyl's Avatar
jackyl
jackyl is offline
Default will this Avon tire fit the deuce rim, instead of the dunlop 180
iam about to change my rear rim to a deuce rim. i wanted a 180 tire, but dunlop is the only one i could find, but have heard they wear downfast and are slippery in the rain. so wanted to try the meterlzer or avon, since i have heard nothing but good things about them. so i was woundering if this avon tire will fit the rear deuce rim? the 170 is 175 mm wide and the dunlop 180is 177 mm wide. so i would only lose 2 mm, if you look at the specs on both tires. i just want to make sure first before ordering itthanks. jackyl
Avon Storm ST AV56
The long-lasting; all-weather; high performance sports touring tire. Incorporates the very latest bike tire technology 'Reactive Footprint'. The tires contact patch changes size and shape depending on lean angle - for the life of the tire. Unique construction means excellent performance combined with very long life. 'Super-Rich Silica' rubber compound gives superb wet road grip. Front tread pattern optimised for shorter stopping distances in the wet. Excellent stability and handling whatever the lean angle.
size 170/60ZR17
load/spd/index 72W
rec rim(in) MT4.50
alt rim(in)min/max. 4.25-5.50
width (mm) 175
dia. 634
Old 01-12-2008, 06:57 PM
cdestuck's Avatar
cdestuck
cdestuck is offline
Default RE: what brand 180 tire will fit on a rear duece rim?
I recently replaced both of my warn out stock tires with thew Metzler 880 tire. Like them but did find that especially with the front tire you got to jack up the tire pressure. Had a bad 40 to 30 front wobble until I found out that I needed 42 lbs in the front. Use 40 in the rear.
Old 01-12-2008, 11:57 PM
itsaw0rkinpr0gre$$'s Avatar
itsaw0rkinpr0gre$$
itsaw0rkinpr0gre$$ is offline
"Seeker of Freedom"
I believe Dunlop is the answer to the 180 question. Don't think anyone else makes the type of tire you need.
Old 01-13-2008, 07:47 AM
jackyl's Avatar
jackyl
jackyl is offline
ORIGINAL: Deuces R Wild
deuces r wild, will the avon storm st av56fit the rim?
Old 01-13-2008, 08:17 AM
itsaw0rkinpr0gre$$
"Seeker of Freedom"
I believe that would fit.
Old 01-13-2008, 09:31 PM
2deuce's Avatar
2deuce
2deuce is offline
Default RE: will this Avon tire fit the deuce rim, instead of the dunlop 180
If you go to the Avon web site and put in your type of bike, it will tell you what tire to use. On my Deuce, I was going to Venoms but they didn't make a Venom to fit the rear of the Deuce. They had me use the Sport Touring tire, which had almost the same tread design as the Venom.
On another note, I had a 180 Metzler on the rear of a Yamaha, which barely fit in the track on a trailer. The 160 Avon on the Deuce was bigger than the track.
Chevync20
07-20-2009 11:10 AM
morrishuckeba
02-23-2009 05:49 AM
jasonyesensky
05-29-2008 02:08 PM
jackyl
01-15-2008 09:34 AM
jaymcgil19
08-05-2007 08:33 AM
Quick Reply: will this Avon tire fit the deuce rim, instead of the dunlop 180
Top
© 2024 MH Sub I, LLC dba Internet Brands
Follow Us
