drive belt replacement
RE: drive belt replacement
It's kind of a big job. You have to remove the inner and outer primary, clutch, and starter. The only specialy tool you need is something to hold the primary chain stable while you unbolt the clutch and stator. You can buy a special tool from HD, J&P, or wherever. I went down to the used sporting goods store and bought an old hockey puck. I cut that down to the width of the chain and jammed it in there.
Here's a link that will show the replacement on a bagger to give you an idea of what's involved.. https://www.hdforums.com/m_98004/tm.htm
ORIGINAL: bobcowan
ORIGINAL: truethumphd
or just use a impact, no special tools necessary!
ORIGINAL: bobcowan
