Belt Dressing?
Old 11-22-2007, 08:38 AM
Arizona Flash's Avatar
Arizona Flash
Arizona Flash is offline
Default Belt Dressing?
Anyone know what to use on the rear drive belt as a "lube"? I had a tube of great stuff specifically made for belts. Great stuff for here in the hot, dry Arizona desert. Can't remember if HD made it or not. Was sort of like clear Vasoline but a little thicker and came in a "toothpaste" tube. Used it on my previous '91 FXSTC for years. Was great to add an occasional small dab on the sides of the belt. Kept the belt quiet and riding on the sprocket nice and smooth without attracting dirt. I must have tossed it out by mistake.
Old 11-22-2007, 08:59 AM
BadBobOk's Avatar
BadBobOk
BadBobOk is offline
Default RE: Belt Dressing?
Try some of this.
Old 11-22-2007, 09:17 AM
Arizona Flash
ORIGINAL: BadBobOk
Try some of this.
Thanks, BadBobOK. If this isn't it, it may be dang close. All I have to do is smell it and I can tell if it's the right stuff. The older HD belts were more "rubbery" than today's more "platic-y" belts. So, they benefited from some sort of "lube". It really was not a "lube". More like a wax. Extremely thin coat was all that was needed. HD and Gates never admitted it, but some sort of goop was advantageous. With today's plastic-y belts, the need may not be as much, but the stuff was always nice to have handy in the tool box chemical drawer.
Old 11-22-2007, 09:34 AM
BadBobOk's Avatar
BadBobOk
BadBobOk is offline
It's what I use on my belt edges. Seems to work just fine.
Old 11-22-2007, 10:25 AM
BULLDOG88's Avatar
BULLDOG88
BULLDOG88 is offline
I have always just used a bar of ivory soap. I rub it on the sides of the belts on my oldler cars every oil change. No problems with my 07 carbon fiber belt. If it did rub I would be sure to use it first.
Old 11-22-2007, 10:27 AM
BadBobOk's Avatar
BadBobOk
BadBobOk is offline
ORIGINAL: BULLDOG88
Won't stand up to the rain though.
Old 11-22-2007, 10:54 AM
MNPGRider's Avatar
MNPGRider
MNPGRider is offline
ORIGINAL: BadBobOk
ORIGINAL: BULLDOG88
But your bike will float !
gerald martin
13
10-17-2021 06:21 PM
zeus33
11-12-2013 11:18 AM
Gwjvw
07-16-2009 09:16 AM
buford
17
05-16-2009 10:53 AM
AlCherry
03-14-2009 07:34 AM
Quick Reply: Belt Dressing?
