super glide battery removal
Old 11-10-2007, 08:49 PM
NOPOINTS's Avatar
NOPOINTS
NOPOINTS is offline
Stage II
Default super glide battery removal
i am trying to remove the battery but can't figure it out. please help.
Old 11-10-2007, 09:24 PM
sharkey's Avatar
sharkey
sharkey is offline
Default RE: super glide battery removal
You joined to ask that?
What year is your bike?
Old 11-10-2007, 09:32 PM
NOPOINTS's Avatar
NOPOINTS
NOPOINTS is offline
Stage II
2005
Old 11-10-2007, 10:14 PM
sharkey's Avatar
sharkey
sharkey is offline
OK; looking at the battery from the side there's a bolt under the ignition (unless you have a wide glide...) that will lower the battery box and on the frame below it is the bolt that secures the battery box to the frame; loosen thebottom one first then you can undo the top one to lower the battery and box. You should remove the seat first (take out the bolt at the back of the seat going into the fender and pull back and up on the seat) and disconnect the NEGATIVE battery lead; you may see it as the cable going to the frame; the black one, perhaps...amI any help?
Old 11-12-2007, 08:24 AM
Wags1's Avatar
Wags1
Wags1 is offline
Step 1...go buy the service manual....
Old 11-12-2007, 09:13 AM
Cryptoboy's Avatar
Cryptoboy
Cryptoboy is offline
Received 3,877 Likes on 1,415 Posts
ORIGINAL: Wags1
Step 2....read the service manual!
Gr3gIcky
02-18-2024 09:40 AM
Rebyl
05-23-2010 06:38 PM
wideone
03-21-2008 07:13 AM
Lasher66
02-23-2007 08:46 PM
phocis
08-09-2005 01:55 PM
Quick Reply: super glide battery removal
