2002 wide glide primary
Old 11-10-2007, 07:38 PM
robswglide's Avatar
robswglide
robswglide is offline
Default 2002 wide glide primary
now, just got this bike..Noticed a small drip under the primary, seems like maybe the plug, is there an o-ring there , If so can I match it with one at the local hardware store, I do I need to find the dealer?????? also Im fixing to go with mobil syn 20w50 in the engine, will that work fine in primary also???
thanks
Old 11-10-2007, 08:49 PM
JLOCKHART29's Avatar
JLOCKHART29
JLOCKHART29 is offline
Default RE: 2002 wide glide primary
Primary doesn't have o ring. Just screws in and is easy yo strip out. I always use a torque wrench on this one just to be sure and wrap threads with teflon tape as I do all drain plugs. Clean up good and make sure thats where its leaking and not outer primary seal. If it is leaking at plug pull it and clean up. Retorque and make sure its not all ready striped.
Old 11-11-2007, 09:27 AM
robswglide's Avatar
robswglide
man, its hard to tell where the leak is.... after the bike is riden, then brought home and parked ,about 15 minutes or so later there will be a small drip the size of a qtr there, and thats it, it dont continue to leak...looked around under there and it is wet looking underneath also, directly behind the primary plug, behind the sprockett.
Old 11-12-2007, 04:59 AM
JLOCKHART29
The reason I say clean it good is that the starter jack shaft seal is bad to go leaking. It is located on the back side of primary and above the drain plug so if not cleaned up hard to teal where its coming from. Get some degreaser and clean it real good and dry it well. Then take a short ride. Not long just enoug to make it start leaking.Get a peace of white paper towel of tolet paper and start dabbing (not rubbing) around looking for oil on the paper. The fact that it stops leaking makes me think if might be a seal.
Old 11-12-2007, 09:57 AM
robswglide's Avatar
robswglide
you would think it would be easier to see where it comes from.. I thought it was the plug, but Now I dont think so... Like I said, it happens after a ride and only leaks about a quarter size spot and dont continue to leak... you have the primary plug and behind there, there is a large sprockett and behind that sprockett it looks wet...
Old 11-12-2007, 10:01 AM
robswglide's Avatar
robswglide
So , if its a seal in there, how bad is that to change, cost?? Im sure It will be fine for awhile, just had leaks.
Old 11-12-2007, 11:16 AM
JLOCKHART29
Sure it will be fine. Not something that is going to go out catastrofically. Just pisses you off good. lol Fixing it is not hard just takes time as the inner primary has to come off. Only special tools is a locking bar that I can tell you how to make easy and a 1 1/2 inch socket. Need the manual and I don't believe that year modles shop manual tells you that starter bolts have to be backed out to drop the inner. Not removed just backed out.
Old 11-14-2007, 01:54 PM
02 Wydglyd's Avatar
02 Wydglyd
02 Wydglyd is offline
My 02 Wideglide started doing the same thing shortly after I got it a year and a half ago. Turned out to be the inner seal. Had it fixed during my 5000 mile service. Even though I bought it used from an individual, the dealer didn't charge for fix since they sold it new and it only had 5000 miles on it. No problem leaking since then.
Old 11-18-2007, 09:49 AM
robswglide's Avatar
robswglide
thanks, when I get ready to fix it I will get back on here for help..
Fishonsc
11-01-2016 12:49 PM
fatkidfrank
Oil Archive (no new posts)
08-09-2012 03:05 PM
boomscatty
10-05-2011 06:50 AM
Doug S
EVO
37
03-18-2010 04:26 AM
oldroadie
EVO
16
09-15-2008 11:14 AM
Quick Reply: 2002 wide glide primary
