Softail Air Ride
Old 12-21-2005, 03:23 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default Softail Air Ride
Lergends Air Ride Found... HERE
Legend Air Ride Suspension System For Softail Models Adjustable air ride suspension allows complete control of your bike's ride height and load carrying capacity. Now you can have a smooth ride without bottoming whether riding solo, or two-up and loaded for touring. Up to 700 lbs load capacity with NO bottoming!
The Legends system also allows your rear fender to have a tire hugging profile when parked or cruising down the boulevard, or raised for suspension travel on rough roads and highways. Legend air suspensions are complete kits and include compressor, gauge with handlebar mount, switches, installation hardware and instructions. Available in chrome or black anodized finish. Optional rocker box gauge mount sold separately.
• Components machined from 6061-T6 aluminum.
• Direct bolt-on replacement for stock style Softail shocks.
• Lowers bike 3" at the touch of a button.
• Ride height is adjustable on the go.
• Small on-board compressor mounts behind transmission using existing mounting holes.
• Dual Kevlar based air springs.
• Installs in 1 to 1-1/2 hours - no special tools required.
• Fits all Softail models 1989-1999. Kits can be vendor modified to fit 1984-1986 Softail (unit must be sent to vendor after purchase, information included in kits).
• Hardware and Instructions included Not for 2000-up Softail models.
220500 Black finish Retail $1,595.00
220505 Chrome finish Retail $1,795.00 Accessories
220510 Chrome rocker box gauge mount retail $109.99
Also Progressive Suspensions...air tail..Found... HERE
So much more than a lowering kit. The Airtail® suspension system was designed to be the smoothest riding, best performing suspension system for your Softail™ chassis. Made with Progressive Suspension’s highest quality custom tuned damper, precision machined components, and show-chrome finished covers, the Airtail® suspension system is the perfect blend of engineering excellence and industrial artistry.
The Airtail® system is actually a pair of two individual shocks, a coil and air shock, working together to give you the ideal ride. The Coil Shock is your primary spring and supports the bike while providing support against bottom-out.
The Air Shock’s main air chamber is divided into a positive air spring and negative air spring. The positive air spring gives you additional progressive spring force that also helps to resist bottom-out. Using our optional on-board compressor, the negative air spring can be pressurized to pump the length of your shock down, which lowers your bike. Your maximum ride height is regained by bleeding the air out of the negative air spring via an on-board purge. The entire Airtail® system consists of a Coil Shock, a dual chamber Air Shock, an optional on-board compressor, all necessary controls, lines, and fittings
Old 12-31-2010, 10:32 AM
J.D.1's Avatar
J.D.1
J.D.1 is offline
Former Sponsor
Default Shotgunshock found here
Billman
Softail Parts
38
10-27-2021 11:56 AM
Sonic69
11-14-2010 10:29 PM
raaaaaa
Air Suspensions
18
09-18-2009 04:06 PM
rotorcrazy
04-18-2009 08:20 AM
rkeith01
05-01-2008 08:14 PM
Quick Reply: Softail Air Ride
