'89 harley sportster oil change
Old 11-06-2007, 03:04 PM
oomchu's Avatar
oomchu
oomchu is offline
1st Gear
Default '89 harley sportster oil change
I recently bought an '89 883 Sportster. My question is where the heck is does one drain the oil from. There's no drain plug, and there's no hose I can conveniently remove. The only option I can see is to remove the hose from the bottom of the oil pan, in which case oil goes everwhere, or just yank the the entire oil pan out so I can dump it out into an oil pan, not a very viable option either.
Old 11-06-2007, 03:17 PM
JosephGarcia's Avatar
JosephGarcia
JosephGarcia is offline
Default RE: '89 harley sportster oil change
I have a '88 and supposedly the Oil Drain Hose runs from the oil tank to a dead end on the battery tray. Stuck with a hose clamp. I can see it looking at the bike, Haven't done my first oil change in my onwership of the bike yet though.
http://www.linson.us/harleydavidson/sportsters/bertshowto/berts_how_tos_oilchange.htm
here is the procedure with pictures and everything. I will be doing mine soon as well.
hope this helps.
EDIT: i posted and clicked the link and its not working, try copy and pasting it if its not working for you.
Old 11-06-2007, 03:38 PM
oomchu's Avatar
oomchu
oomchu is offline
1st Gear
yep, I see it. Thanks.
Old 08-09-2018, 11:48 PM
Randall Parks's Avatar
Randall Parks
Randall Parks is offline
Stage I
Default Can't view link
I too have an 89 883 and looking to do a complete oil change minus the transmission primary... looking for the same help as above
Old 08-10-2018, 07:18 AM
John Harper's Avatar
John Harper
John Harper is offline
Received 1,645 Likes on 1,135 Posts
It's easy, there's a hose end under the battery tray. Don't forget to put some oil inside the new filter, and a light film on the filter seal. Don't overtighten filter, it's not necessary and will make it much easier to remove next time. Use a strap wrench if the filter is stuck tight. A little more than 2.5 quarts of oil and you're good! I use a WIX 51215 filter, easy to get off Ebay.
John
Rob Roy's Revenge (04-20-2023)
Old 08-10-2018, 07:28 AM
Ben221's Avatar
Ben221
Ben221 is offline
Make sure you run it first to to get the maximum oil into the oil tank. The oil settles slowly into he case on my 1990.
Order the manual off ebay for around $35 for a slightly greasy one.
Old 04-22-2022, 03:35 PM
83XLX's Avatar
83XLX
83XLX is offline
Deleted
Old 01-11-2023, 08:51 PM
gremlinsteve's Avatar
gremlinsteve
gremlinsteve is offline
Completed my 1275 swap
cranked it up and she sounds healthy
Old 01-12-2023, 06:41 AM
slw210's Avatar
slw210
slw210 is offline
But, did you change the oil?
Another victim of the "Related Threads" ignorance?
John Harper (01-12-2023)
Old 04-19-2023, 07:05 PM
McGurk's Avatar
McGurk
McGurk is offline
Picked up another lil Sporty 883 this morning. Purrs along like a watch.
File Type: mp4
Quick Reply: '89 harley sportster oil change
