WHAT SIZE REAR TIRE WILL FIT A 04 FXST?
Old 11-03-2007, 03:20 PM
inkpig's Avatar
inkpig
inkpig is offline
Stage III
Default WHAT SIZE REAR TIRE WILL FIT A 04 FXST?
Does anyone know what size rear tire would fit on a 2004 FXST without modification to the struts, frame, etc...? I have been told a 200 should just fit.
Old 11-03-2007, 08:54 PM
FXSTI Guy's Avatar
FXSTI Guy
FXSTI Guy is offline
Default RE: WHAT SIZE REAR TIRE WILL FIT A 04 FXST?
200 tire won't work on your 2004...it will interfere with your final drive belt.
Old 11-03-2007, 10:47 PM
inkpig's Avatar
inkpig
inkpig is offline
Stage III
What is the biggest tire that will fit?
Old 11-03-2007, 11:55 PM
JLOCKHART29's Avatar
JLOCKHART29
JLOCKHART29 is offline
You got it on now with out relaceing with a 180 Duece rim. I have heard (no experance) that will let you run a 180 if you carefully recenter the tire. But again thats just what I heard and you know how that goes. If you go any bigger belt and inside fender support plates will rub. Not pretty. Stick with the stock tire unless changing swing arm or struts.
Old 11-09-2007, 09:17 PM
G5jive's Avatar
G5jive
G5jive is offline
I run a 150. Any more than that and I think it looks retarded on a stock 16" rim with all the overhang.
Old 05-22-2008, 11:32 AM
'05Train's Avatar
'05Train
'05Train is offline
So wait, if you were to change the belt to a 2006+ one, and swap out the fender and supports, you could run a 200mm tire & wheel?
Old 05-26-2008, 11:01 AM
Lundee's Avatar
Lundee
Lundee is offline
160 will fit barely. Not really worth it because you can't slam it w/o rub. You can run a 180 w/a wider 5.5 rim but, you'll need a new fender. A 200 will fit w/ the new skinny belt and front/rear pulleys, rim, fender.
Chadm2
03-15-2014 12:17 AM
jcbikn
Wheels/Tires
12-04-2011 12:08 AM
itsstock
09-21-2007 08:55 AM
Ghost_FL
10-17-2006 04:54 PM
JimboFXD
06-26-2006 11:54 PM
Quick Reply: WHAT SIZE REAR TIRE WILL FIT A 04 FXST?
