HD Vacuum Petcock
Old 11-01-2007, 04:39 PM
mvinc01's Avatar
mvinc01
mvinc01 is offline
Default HD Vacuum Petcock
Noticed fuel leaking from the fuel line/petcock connection yesterday. Went to gently remove the fuel line from the petcock to inspect and clean up. When I loosened the clamp to remove the line, the brass male tube came right out of the plastic petcock housing. I called my HD dealer. Asked if it can be repaired or glued. Guy said "no way". They can special order it, or I can replace with an aftermarket ranging from $20-$100. I can't do special order. So, I'm sitting there thinking "what the hell. I'll try and glue it anyway" Cleaned it up good, inside and out. Placed a little bit of Super Glue! on the brass fitting and shoved it back in. Trimed and reatatched the fuel line. Ran for a couple mins - no leaks. Rode to work today - no leaks. Just checked again - no leaks. If it starts to leak, I'll probably replace with a Pingle petcock.
Question: If I replace with AF (Pingle or other gravity feed)petcock, what do I do with the vacuum line connection?
Thanks!
Old 11-01-2007, 06:44 PM
Mr E's Avatar
Mr E
Mr E is offline
Default RE: HD Vacuum Petcock
MV
If the aftermarket petcock does not require vacuum you have to plug the line. You can not leave a vacuum line open.
Old 11-02-2007, 08:35 AM
ride99fxd's Avatar
ride99fxd
ride99fxd is offline
I replaced mine with a Pingle, and put a rubber nipple over the vacuum port on the manifold.
shovelheadal (01-29-2024)
Old 11-02-2007, 12:04 PM
mvinc01's Avatar
mvinc01
mvinc01 is offline
Thanks guys. How do you like the Pingle petcock? Is it worth the high dollar $100 price, compared to other aftermarket petcocks?
MV
Old 11-02-2007, 01:29 PM
bobcowan's Avatar
bobcowan
bobcowan is offline
You're living on borrowed time. Crazy glue is not going to last. It's going to fail at the worst possible time, and then you're hosed.
For aftermarket petcocks, Pingle is very good. I used one for many miles without any problems.
But, you don't need an expensive racing part. The pingle is designed to be a high flow unit, for engines that need that kind of flow. You don't. You can get a decent Sifton part for a lot less. If you scout around you can find a used factory take off for just a few bux.
Old 11-02-2007, 02:46 PM
ride99fxd's Avatar
ride99fxd
I had issues with cheaper ones seeping fuel in the "off" position. The Pingle has been rock solid.
jf7689
EVO
01-04-2018 11:02 AM
Runcy12
07-20-2016 02:26 PM
97EGC
07-23-2015 11:24 AM
Frontovik
06-06-2011 03:08 PM
fred0k
11-26-2007 02:24 PM
Quick Reply: HD Vacuum Petcock
