Any way to make Rinehart True Duals louder?
Old 10-15-2007, 06:39 AM
Plow64's Avatar
Plow64
Plow64 is offline
Default RE: Any way to make Rinehart True Duals louder?
Get the hi-flo performance baffles that Rinehart sells.
Old 10-15-2007, 06:47 AM
HD Attitude's Avatar
HD Attitude
HD Attitude is offline
OK. Theres nothing to "DRILL OUT" as you will see. Take the back part of the exhaust off and unscrew the backend cap. their are three hex screws. Tap that off and take a long screw driver and tap out the baffle. Before you do that spray the he*l out of the baffle. It will pop out. NOW you can see that theres no reason to drill. theres nothing to drill. Its already wide open except for a small area in front. thats for some back pressure. If you buy the performance baffles, they will quiten the bike down some believe it or not.
Heres the thing. If your wanting LOUD PIPES and your not worried about prformance. Take the baffels out and thats the loudist your going to get those pipes but its going to be LOUD and you will loose some bottom end. You might want to have your bike put on a dyno after removing the baffels also. I really dont know why you would want it louder, its going to be hard for others to ride behind you with blown out pipes and I dont know where you live , but some states have laws now about loud pipes.
Good luck.
Old 10-15-2007, 11:46 AM
stimul8ing guy's Avatar
stimul8ing guy
stimul8ing guy is offline
leave the mufflers off!
Old 10-15-2007, 12:12 PM
catracho's Avatar
catracho
catracho is offline
Try the Thunderheaders!!!
They are Loud.
Old 10-15-2007, 12:42 PM
JDean's Avatar
JDean
JDean is offline
Why do people buy touring bikes and want to install loud pipes? I have Rinehart true duals on my 05 standard and installed the performance baffles that would not work on my friend's 07 Rineharts. I rode all summer with the performance baffles and about ready to re-install the quiet baffles.
Old 10-15-2007, 12:48 PM
SoCal_Pappy's Avatar
SoCal_Pappy
SoCal_Pappy is offline
PULL THE BAFFLES OUT...
But you'll more then likely loose performance
Old 10-15-2007, 06:21 PM
SkyDriver's Avatar
SkyDriver
SkyDriver is offline
Yes there is something to drill out if you pull the bafflesinside RHslip on mufflers. Been there, done that. Again, this is not an easy task. If you pull the end caps, you will see the baffle. Mine required a slide hammer to remove but all thats over now. Reinstall is a pain too as the metal will be deformed while pulling them. Dont know if the true duals mufflers are the same or not but I don't see why they wouldn't be. Good luck.
[IMG]local://upfiles/25366/C516FDA26DE34868962527AF7AD17317.jpg[/IMG]
Old 10-15-2007, 07:41 PM
classicjade01's Avatar
classicjade01
classicjade01 is offline
pull the mufflers off and just run the headpipes.....did it to my 1200 sporty once long ago....very loud.
Old 10-16-2007, 12:44 AM
msocko3's Avatar
msocko3
msocko3 is offline
Keep running around and pissing off the public an the 106db will become 89db real quick. Those dang things are plenty loud to begin with. I have a neighbor who has them on a stock 88" and I hear him coming home each night he has been out late.
rscott82
10-07-2014 05:18 PM
Cutting88
05-12-2013 04:14 PM
kdfoster
06-21-2012 12:37 AM
sunrise rider
09-27-2008 08:57 AM
my2004harley
12-27-2007 03:18 PM
Quick Reply: Any way to make Rinehart True Duals louder?
