cost to install 124" big bore kit
Old 10-02-2007, 12:50 PM
cnnesseth's Avatar
cnnesseth
cnnesseth is offline
Default cost to install 124" big bore kit
I have a 1999 Electra Glide which is stock EFI that needs much more HP. I want to put a 124" big bore kit on it. Was wondering the cost to install and which way I should go?
Old 10-02-2007, 01:05 PM
axe11's Avatar
axe11
axe11 is offline
Default RE: cost to install 124" big bore kit
I can strongly recommend Wes at Cycle-Rama in Pinnellas Park, FL. They have the performance package you're looking for, a 124 or 131 c.i. twin cam package for a listed $6575.00. Click on http://cycle-rama.com/HPProducts.html for a link to this particular package. Cycle-Rama's superb reputation as an engine builder is what you get behind their builds, but their prices are very good too. Give Wes a call or put in a question on their Web site; you'll get the education you want about a build 120 or over at the very least. Good luck with your build.
Ride safe,
axe11
Old 10-02-2007, 03:28 PM
ken thompson's Avatar
ken thompson
ken thompson is offline
The Schlong Man
Can you go from 88" to 124"?
Old 10-02-2007, 03:48 PM
axe11's Avatar
axe11
axe11 is offline
Hello Ken,
If it was my post to cnnesseth you are referring to, the answer is yes of course. I'll post, below, the basic 124 package information from Cycle-Rama so you'll have the general idea. But you owe it to yourself to give Wes a call and discuss what you might have in mind or where you'd like to go with a build, and he'll take you there with the information you need. Check this out for a 124 or 131 build, but note that would still need to "hook" it with clutch upgrade, etc, so some peripherals notwithstanding:
124 or 131 cubic inch twin cam engine package
* (1) Performance Ignition Module
* (1) 4 5/8 stroker crank
* (1) 4 1/8 (124) or 4.250 (131) pistons and cylinders
* (1) Set of heavy duty cylinder studs
* (1) Set of gear drive cams. Cams inner & Outer gears, new cam bearings & heavy duty cam bearing plate
* (4) Performance lifters
* (1) Adjustable pushrod kit and pushrod tubes
* (1) Performance engine gasket kit
* (1) Roller Rocker arms
High flow, High velocity, Cycle-Rama CNC Ported Cylinder Heads. Install over-sized intake seats, bronze alloy valve guides installed and honed to size. 2.100 Custom Hi-Flow stainless steel intake valves and 1.615 Hi-Flow nitrate coated exhaust valves. Multi angle valve job on intake, radius angle valve job on exhaust. Set valve to valve & seal to retainer clearance. Install heavy duty valve spring kit and set installed valve spring height. Install compression releases. Flow test heads. CC chambers & Mill heads.
Engine is disassembled cleaned & inspected, bottom end is mocked up & clearanced for stroker crank, top case is bored, cases are clearanced for cams. Rocker boxes are clearanced, engine is clayed, piston to valve clearance is measured and valve pockets are cut to correct depth, engine is reassembled.
Any worn out of spec. OEM parts will be extra, prices are subject to change.
Prices are for parts only and using customer parts.
Additional labor for bringing in motorcycle for R&R motor and set-up for carb or fuel injection for break in. Please call for more information.
$6575.00
Ah, yea, that's what I call poetic justice. I don't work for them or anything, just passing along the info. Take care and ride safe.
axe11
Old 10-02-2007, 04:02 PM
Motown_HOG's Avatar
Motown_HOG
Motown_HOG is offline
What do you plan on doing- towing a boat behind your scoot?
Old 10-02-2007, 05:35 PM
kingtut73's Avatar
kingtut73
kingtut73 is offline
forget the 124ci do the merch 200ci upgrade 260hp.. now your talking HP!
if you gonna get a ***** enlargement look like a **** star while doing it.[sm=yikesomg.gif]
Old 10-02-2007, 05:45 PM
kingtut73's Avatar
kingtut73
dont believe me http://www.merchmotorworkz.com/pressrelease.pdf
Old 10-04-2007, 11:30 PM
Black Flag's Avatar
Black Flag
Black Flag is offline
...seth.
If you are interested in a good read, Donny Petersen has an in-depth article in the November issue of American Iron Magazine about building a 124" engine on Twin Cam cases using mostly S&S parts for the upgrade.
This is Part I of a series of articles. I like to read Donny's opinion because he seems to be a thinking man's mechanic, not just a mouthpiece for the Motor Company.
Have you thought about swapping out your old engine for a brand new crate motor? This would give you the benefit of a new warranty on the crate motor, plus an opportunity to build the old one at your leisure. Just a thought...
Old 10-05-2007, 11:15 AM
rome304's Avatar
rome304
rome304 is offline
shop around but a nice piece of change.
Old 10-05-2007, 02:48 PM
swipter's Avatar
swipter
swipter is offline
ORIGINAL: kingtut73
I would kill myself. I know they go as fast you twist the throttle but it would take much twistin'.
joee
Engine Mechanical Topics
08-23-2014 09:30 AM
lkr0
10-15-2007 12:31 PM
Manish_Hawg
10-03-2007 09:52 AM
murraypj
07-18-2007 06:28 AM
zoomie67
12-11-2006 03:47 PM
Quick Reply: cost to install 124" big bore kit
