Handlebar diameter
Old 12-06-2005, 05:20 PM
Iron Legend's Avatar
Iron Legend
Iron Legend is offline
Default Handlebar diameter
Anyone know what the handlebar diameter is on my '03 883? I will in all probability be changing them out in the spring and want to make sure I order the correct diameter. Tks.
Tom
Old 12-15-2005, 12:29 PM
MuddyXL's Avatar
MuddyXL
MuddyXL is offline
Default RE: Handlebar diameter
I think they're one inch but I've been waiting to see somone answer this myself.
Old 12-16-2005, 02:55 AM
Big Cholla's Avatar
Big Cholla
Big Cholla is offline
IRON: They are 1 inch diameter, unless someone before you swapped them out to the larger size. ........ BC
Old 12-16-2005, 07:24 PM
lennyeagle's Avatar
lennyeagle
lennyeagle is offline
stock is 1 inch if they are original.
Old 12-16-2005, 10:03 PM
Iron Legend
Yep, they are original. Apprecite the feedback......Thanks all.
Tom
Old 12-17-2005, 03:33 PM
Iron Legend
Yep B C they are stock from the factory, never changed, so now that I have confirmation from a couple of you guys as to their 1" dia. all I gotta do now is look around for a suitable set of pullbacks'. Tks.
Tom
Old 12-18-2005, 02:39 PM
MuddyXL's Avatar
MuddyXL
MuddyXL is offline
Somebody correct me if I'm wrong but aren't metric bikes bars 7/8" generally and HDs are 1".
I noticed the bars on my Sportster also have indentations for the cables to enter the switch housings that you won't find on a run-of-the-mill round bar.
Old 12-18-2005, 02:55 PM
Iron Legend
Some metrics may have 7/8" bars, I don't know for sure, but the bars on the '99 V* 650 I had B4 changing to the sporty were stock 1".
Tom
Old 03-30-2007, 11:04 PM
mplecha's Avatar
mplecha
mplecha is offline
is that true for 07's as well? I wanna change the bars on mine, but wasn't sure of the diameter..
Old 05-20-2016, 02:09 PM
kennethnewhder's Avatar
kennethnewhder
kennethnewhder is offline
5th Gear
Is 2014 road king 1 inch also? I have 10 inch apes... I'd like to be a few inches higher & little more pullback.. Can I get the bars higher & more pullback by using pullback risers?? I've seen some around 4-5 inches with what looks like about 45 degree on the risers?? I'm trying to do this without new bars & lots of labor cost!!
Quick Reply: Handlebar diameter
