primary oil substitute
RE: primary oil substitute
ORIGINAL: opiate9680
Even if its just straight automobile synthetic oil with a 15w-50 or 20w-50 weight from autozone or advance auto parts or wally world or whatever?
There has been debate about whether motorcycle oil is any different than car oil and so far nobody has found any significant differences. Motorcycles are much harder on oil than cars, but there's no evidence that motorcycle oil holds up better than car oil. I think a lot of people have used mobil 1 car oil in there bikes without any problems (again you want to confirm this).
ORIGINAL: brohrs
Iam now totaly confused about this post. One says you will die if you use the engine oil in the primary now someone says you will get a BAZILLION miles on it.
HD sport trans fluid IS motor oil. Ever notice how HD recommends Synth 3 in the primary/tranny hole if you switch to a synthetic blend? What do you think Synth3 is? Its 20-50w motor oil.
Received 1,211 Likes
ORIGINAL: MegaHDman
I personally make sure the 15-50w or 20-50w sythentic oil says "vtwin" or " motorcycle", "4 stroke" etc. on the bottle. Supposedly there are different additives in a motocycle blend synthetic. I can't verify that becuase Ive never sent out samples to be tested.
I wrote up (shameless plug for me) a 2 part article on oil basics. It's in the top section of the oil forum. I tried to make it easy to understand, and not too technical. Give it a read if you're interested.
