Sponsored by: Jekill and Hyde
S&S 570G cam
Old 11-25-2005, 03:11 PM
bemisbunker's Avatar
bemisbunker
bemisbunker is offline
Default S&S 570G cam
Why isn't this camshaft very popular?
Old 11-25-2005, 03:18 PM
MegaHDman's Avatar
MegaHDman
MegaHDman is offline
Default RE: S&S 570G cam
Not sure what your talking about. Its a pretty popular grind. Good low and midrange torque cam.
Old 11-27-2005, 12:10 AM
HDWRENCH's Avatar
HDWRENCH
HDWRENCH is offline
I like it I am fan of the S&S cams as they have some gentle ramps to them. I would not use them much over 10.1 But other than that they work well for a decent low end and soild mid range punch
Old 12-02-2005, 07:04 PM
traveler's Avatar
traveler
traveler is offline
I've got the S&S 510G's in my 88 and they're working GREAT!!!! I'm unaware of a bigger "bolt-in" cam that works with all the stock valvetrain. Will it work in a 98 kit with heads? It's REALLY similar to the T-37 Andrews being used, and if so, that's cool, as i can use the stock valvetrain, and save $$$$$$, which, by the way, I'm all about these days.[]
joe
Old 12-04-2005, 11:08 PM
zigzzagz's Avatar
zigzzagz
zigzzagz is offline
1st Gear
Actually the 570 is a rather popular cam. Works really well with the very inexpensive (these days) SE performance heads and flat top pistons. Makes for a 100+ lbs/ft of torque. Very good low and mid range, and with a little bit of head cleanup and valve grind can make some surprising HP as well.
zigz
Old 01-09-2006, 12:02 AM
VegasFatSE's Avatar
VegasFatSE
VegasFatSE is offline
How would this cam perform on a 05 SE Fatboy with the 103? I see the cam in my bike has a lift of .538 already.
Old 02-22-2007, 11:36 AM
QuickTurn's Avatar
QuickTurn
QuickTurn is offline
3rd Gear
I see by the posts that most of you have big cubes with the 570...I put one in my 88 EFI motor and it's a bit radical. Runs good once off idle but rough starting off. Having problems with fuel/mixture and will be on dyno next week.
At this point, I am trying to decide amongst tuners...PC vs SERT...both seem to have good qualities although I have read good and bad on many forum threads.
This message isn't about which tuner...more about your thoughts on the 570 with the 88...anybody else out there with big lobes on small cubes...?
Thanks...
Old 02-23-2007, 02:38 AM
JLOCKHART29's Avatar
JLOCKHART29
JLOCKHART29 is offline
https://www.hdforums.com/m_1248302/tm.htm Link to my Hippo build with pics I finnished Tues. s&s 570
Old 02-27-2007, 12:53 PM
99igor's Avatar
99igor
99igor is offline
I have been running a 570 cam in my bike for better than a year now. Two thumbs up, this thing rocks!!!
Old 03-02-2007, 11:38 PM
QuickTurn's Avatar
QuickTurn
3rd Gear
Nice job...Great Pics...! ! !
I finally decided the 570G's were too big for my diminuitive 88...went for the Andrews 37G with .510 lift, a little less duration. Just had it dyno'ed today and am not happy...spits and sputters below 1700 driving like a normal person 'round town...but if I drive it like I stole it, WOW... Tendency is to want to shift higher to keep the torque up...feels good... Then I put the baffles back in and it rides like a charm only much more power than with the stock cam. Using SERT and will try to get out the kinks with no baffles...
Thanks for the link...
Nick
Quick Reply: S&S 570G cam
