Ultima 107" motor on a 90 model Bagger
Hey all,
Anyone on the forum running the Ultima El Bruto 107 engine on their bagger? If so would you give any pros or con on the preformance, starting, oil blowby, dependablity or anything relavant to the engine. I am really wanting to try one these engines but would like to get some feedback before investing in the motor. I have posted this in the touring forum also, but thought it more relevant here because the bike I want to install this motor is a 90 model electraglide ultra. I had a S&S 113 on a ridge bike, but the oil blowby was too much. Never did get it stopped.
Thanks in advance for any replies.............
I don't want to run 150 mph for long, but I want to get there as quick as possible..............
paco
paco
RE: Ultima 107" motor on a 90 model Bagger
Ihave installed several 107" Ultima engines in baggers with great results. The 107 is the perfect touring engine & iseasy starting without the compression releases, nice idle, runs cool, NO oil blowby, good mileage, does not require a monster clutch & isnot as exhaust sensitiveas the larger engines. There are no drawbacks to running the 107 & it will put aBIG smile on your face.
You will need a single fire coil, a HD clutch spring or extra plate clutch, Good slip on mufflers or 2 into 1 & an air filter adapter if you want to run a stock style air filter with the Mikuni 45. These engine are a great bang for the buck & very reliable. Good luck with your build & ride safe.
GTC Cycles,
Thanks for the reply. I am in the process of changing the motors out. Just got the 80" off last night. will try toinstall the 107" tonight. When u say HD clutch, I assume you mean a heavy duty clutch spring plate? Do you have any numbers of the diapham clutch spring you use or is it easier to just put another friction plate in? I have ordered a single fire ignition, oil filter mountand an oil cooler, hopefully arriving by the end of the week. Again, thanks for any info.
js124,
thanks for the offer, but i have already recieved the 107". it shouldn't be hard to sell though.
steve
js124,
steve
Original: GTC Cycles
skeptical due to a few reviews I have seen. How long have these motors you
installed been in service on the bikes? My concern would be getting 10K
on the engine and having to pull it down.If that happens then no great price is worth it
GTC Cycles,
Have you had any issues with ignition timing on these motors. On another forum i useI was cautioned about timing.
hotrodroadking wrote:
"Be extremely cautious with the breakin do it like midwest says, also be sure you setup the timing on the motor per the spec's of midwest.
They have had problems with some pistons to cyl clearance that was made worse by poor installation.
If any doubt get someone to help that knows how to setup the ignition. It should be right out of the box but you need to be sure."[/align][/align]Storm4U,[/align]Where are you finding reviews for these or any motors. I called myself searching everything and everywhere before i bought this motor. Asking on several forums about these motors. Since buying I am hearing some negative feedback.[/align][/align]Thanks[/align]
There has been problems with the timing issues on the ultima motors . I have seen the damage first had . It required replacement of the rear cyclinder and piston . I know Ultima ships them now with the timing set . I don't think you can even adjust it . I don't own one but have had a friend or two who have .
