Sponsored by: Jekill and Hyde
t-man 625 cams
Old 08-28-2007, 11:01 PM
drdave's Avatar
drdave
drdave is offline
Default t-man 625 cams
anyone running the tman 625 cams. i know they originally were for softails, etc, but bought a set based on recommendations to go in a 113". anyone with experience on larger motors with this cam?
riding 2000-4000 rpm with single rider. not looking for high rpm hp but good streetability and starting with no detonation problems in really hot summer weather over 100 many days. going in fxdwg with 45 mikuni carb. have been advised they will perform well at 10.25 -10.50 compression ratio in this size motor and have great torque at this rpm range. will have programmable ignition module.
any experience?
Old 08-29-2007, 09:12 PM
mentor70's Avatar
mentor70
mentor70 is offline
Default RE: t-man 625 cams
I have no experiance with them, and I hate to see a question like this go unanswered, so Ill give you my 2 cents.
I thinkits a good grind, I went to the sight to see the specs, It should work fine for what your doing.
you will need to just be mindful of valve to piston clearance.
WhiskeyHarley
06-29-2013 01:44 PM
northeastconfederate
11-10-2008 01:32 PM
BCSG
09-07-2008 07:39 PM
dirtpan
13
10-27-2007 06:12 PM
trigger1911
23
05-23-2007 05:55 PM
Quick Reply: t-man 625 cams
