Primary oil capacity
Old 08-17-2007, 09:36 PM
AF07's Avatar
AF07
AF07 is offline
Default RE: Primary oil capacity
ORIGINAL: nikonf8
last time i check my manual for my deluxe which is a twin cam 88 it stated 26 or 28 ounces i am sure it was not 32. I am not sure what motor you have in the train but if you have a twin cam 88 I would not be putting in 32 ounces
Well if it's an 07, as the poster clearly indicates, it's not a TC88 but rathera TC96.Thatmodel holds exactly 32 ounces in the primary. And that's what it says in the service and owners manual. Not 26 or 28 ounces...
Old 08-17-2007, 10:01 PM
In Memoriam Citoriplus's Avatar
In Memoriam Citoriplus is offline
May our Moderator Rest in Peace
I believe that one of the reasons that the 07's and the 96 inch engines take 32 oz is because they redesigned the primary for the auto adjuster. If you look closely at thedarby cover it is actually slightly higher up on the outer case than on pre 07primary's.
Its easy to see after you open the cover up. On older ones the clutch basket aligns with the hole. Makes servicing the clutch easy. But on 07's the clutch basket is actuallybelow the hole.
On oldermodels putting too much oil in is actually kind of hard because with thehole positioned where it is it just won't hold it with the cover off, and the same is true of the newer 07's. With the hole higher it makes it easy to get the required quart of oil in without it spilling out on you.
Old 08-18-2007, 01:22 AM
brihvac's Avatar
brihvac
brihvac is offline
ORIGINAL: mojojones
ORIGINAL: nikonf8
He has on '07 with the 96 c.i.d, themanual specs primary capacity at 32 oz
I installed the new outer primary cover. Installation was easy and I used a entire quart of oil.
bulldog82098
07-01-2013 10:13 PM
TheSter
09-07-2012 11:54 AM
campdreamer47
Oil Archive (no new posts)
04-22-2012 08:52 AM
WhiskeySierra
03-09-2012 05:00 PM
babyray
04-19-2011 07:36 PM
Quick Reply: Primary oil capacity
