rear brake light issue, wont work, need helppppppppp
Old 07-24-2007, 08:41 PM
jackyl's Avatar
jackyl
jackyl is offline
Default rear brake light issue, wont work, need helppppppppp
ok,HUGE problem. on thw way home from work i almost got rear ended [:@]. first i was very pissed at the cager, so i pulled next to the cager to give her a peice of my mind. but thethe lady was saying my rear brake light wasnt working. so i pulled off and sure enough my rear brake light doesnt work, but the running light part of it works, just does not brighten when using the brake. i have the aux rear running brake light module on my bike, so all the lights come on when you use the brake. ok here is the problem, the running lights work, but when i press the brake(foot or hand) the blinker brake lights come on, but the main light doesnt brighten up when pressing the brake. so when i got home i took off the aux running brake light module, to see if it was messed up. the main light still wouldnt brighten when pressing the brake[:@], but the running light works. so i took the main brake light off and checked the plug and all the pins and connectors, looked fine. put it back inand still just the running light works, but still does not brighten up when pressing the brake. i took myfront brake lever off and checked thelittle module brake box inside your handlebar housing, that worked fine when i pushed it, but still no main brake light. i have checked all fuses, but all good, figured that because the running light part works. do you think its the wholerear light assembly? helpppppppppppp . jackyl
Old 07-24-2007, 08:45 PM
DGlide04's Avatar
DGlide04
DGlide04 is offline
Default RE: rear brake light issue, wont work, need helppppppppp
Not to sound like a smart ***, but did you check the brake light bulb? You didn't say whether this was looked at. It is a 2-filament light, one for the running light and a separate filament that burns when the brakes are applied. Pretty easy to check, or just replace the bulb and see what happens.
Old 07-24-2007, 08:49 PM
fastfxrs's Avatar
fastfxrs
fastfxrs is offline
Ditto on checking the bulb. Then I'd check the wires on the rearbrake light switch. This kind of stuff drives me nuts. I had a '93 lowrider that I never did find the cause of the light not working.
Old 07-24-2007, 09:30 PM
MarkM's Avatar
MarkM
MarkM is offline
Just fixed the same problem on my WG. It was just the bulb. 3157K I think it was.
Old 07-24-2007, 09:46 PM
tuff's Avatar
tuff
tuff is offline
If it is not the bulb........? I would imagine that there is a brake light switch somewhere on the bike. I would have to look and find it or look on the wiring schematics. It could possibly be bad.
Old 07-24-2007, 09:50 PM
jackyl's Avatar
jackyl
jackyl is offline
ORIGINAL: DGlide04
ill check tomorrow on the bulb. i hope it is just the bulb, i hate electrical work. thanks guys. jackyl
Old 07-24-2007, 10:57 PM
jessock23's Avatar
jessock23
jessock23 is offline
My problem was the brke light was on the whole time....
There is a micro switch in the hand controls. When you squeeze the brake it activates the switch. It is very small so it might of **** it self. It has a little rubber cover. You could probably see it with taking anything but you might have to lossen the controls.... (loosen...not remove) as of yet.
Jess
Old 07-24-2007, 11:22 PM
DYNAMITE 1's Avatar
DYNAMITE 1
DYNAMITE 1 is offline
Definatly the bulb, easy peasy
Old 07-24-2007, 11:56 PM
jharp's Avatar
jharp
jharp is offline
My bet is on the bulb, if the running lights come for on for braking that tells you your brake switches, hand and foot control are working fine. The tailight is a dual filament bulb.
Jim
Old 07-25-2007, 12:24 AM
jandlcars's Avatar
jandlcars
jandlcars is offline
Location: NOMAD Milton FL Now Originaly From San Rafael CA
06 Wide Glide the tail /Brake has a circet board and had water in it rotted out board whare wires pluged in
Quick Reply: rear brake light issue, wont work, need helppppppppp
