modify stock mufflers
Old 07-24-2007, 07:26 PM
whwilk1's Avatar
whwilk1
whwilk1 is offline
Stage I
Default modify stock mufflers
looking for information about making stock mufflers sound better.does any one know how this can be done. any info. apprecaited
Old 07-24-2007, 08:01 PM
db2753's Avatar
db2753
db2753 is offline
Default RE: modify stock mufflers
Was kind of wondering the same thing.
Old 07-24-2007, 08:11 PM
SoCal_Pappy's Avatar
SoCal_Pappy
SoCal_Pappy is offline
It can be done - They sell them all the time on E-Bay... But if your going to go that far might as well put on a set on SE or Rush mufflers
Old 07-24-2007, 08:17 PM
BigMoHog's Avatar
BigMoHog
BigMoHog is offline
You can take a hole saw and drill out the plugs on each end of the muffler. If you look at the muffler from the end( ie, inside) you will see a flat, this is what needs to be drilled out. Each end of the muffler. It is a one inch or inch and a quarter. Once they are drilled out you will be able to see through the muffler.
Old 07-24-2007, 08:23 PM
Mad dog 57's Avatar
Mad dog 57
Mad dog 57 is offline
3rd Gear
We have done a couple sets by beating a steel rod or pipe thru it,quick and easy!
Old 07-24-2007, 08:40 PM
BigMoHog's Avatar
BigMoHog
BigMoHog is offline
Yea did my first set with a steel rod too.
Old 07-24-2007, 08:41 PM
04harleyboy's Avatar
04harleyboy
04harleyboy is offline
I sent out some take offs to a guy I found on ebay, he is in Michigan, I think he charged me $150 to do it, they sounded great, and you could see through them. He puts in a 2" ID baffle. If you are interested, PM me and I'll see if I can dig up his email.
Old 07-24-2007, 09:18 PM
Firstclass's Avatar
Firstclass
Firstclass is offline
I know a guy on e-bay were I got mine, this set was 140.00 but he will mod yours to a 1,2or3 2 being the same as SE but a deeper tone for 85.00 plus shipping.
Old 07-24-2007, 09:38 PM
old.gezr's Avatar
old.gezr
old.gezr is offline
Check out fullsac.com, as they modify stock mufflers. Quick turnaround, quality work and good prices. Call and talk to Steve and he will explain the process to you.
Old 07-24-2007, 10:50 PM
aknewbe's Avatar
aknewbe
aknewbe is offline
Along with this mod, you have to get reflashed...........right?
Quick Reply: modify stock mufflers
