Security light stays on... ?'s mean
Old 07-17-2007, 08:30 PM
NoTyme's Avatar
NoTyme
NoTyme is offline
Default Security light stays on... ?'s mean
Anyone know what the red light for the security system means when it stays on for a while after starting? It seems to happen in moist[sm=confused06.gif] enviroments meaningdamp weather... 06 EG
Old 07-17-2007, 08:38 PM
UltraKla$$ic's Avatar
UltraKla$$ic
UltraKla$$ic is offline
Default RE: Security light stays on... ?'s mean
ORIGINAL: NoTyme
You and THIS fellow seem to have the same issue.
Old 07-17-2007, 08:49 PM
Retired_Ted's Avatar
Retired_Ted
Retired_Ted is offline
Probably a historical code - take it to your dealer if you don't know how to read it. I can email you instructions if you are unsure how to retrieve the codes from your speedometer.
Old 07-17-2007, 09:05 PM
NoTyme's Avatar
NoTyme
NoTyme is offline
I think I have something in the service manual that tells me how to read the codes... I'll give it a try.
Old 07-17-2007, 09:09 PM
davzdorado's Avatar
davzdorado
davzdorado is offline
Check all your lights, if one is burned out the Red Key will stay on. Hope this helps.
Old 07-17-2007, 09:11 PM
Retired_Ted
Yes - TRUE - I forgot - check your turn signals and your running lights - bet one is out!
Old 07-17-2007, 09:23 PM
glide's Avatar
glide
glide is offline
ORIGINAL: NoTyme
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 9. If the code is current it will reappear.
9 – Press and release the odometer reset button to continue to the next module.
10 – Turn Ignition switch to OFF.
DTC FAULT CONDITION MODULE
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low EFI
P0563 Battery Volt
Old 07-17-2007, 10:15 PM
NoTyme's Avatar
NoTyme
NoTyme is offline
OK! Great info... If I did this right under "S" i pulled 61121 and then 61112 for trouble codes... I tried a second time and they are now cleared out, so it looks as if I need to ride again tomorrow and re-check the codes. I see nothing under these 5 diget numbers...
Old 07-17-2007, 10:45 PM
rmarion's Avatar
rmarion
rmarion is offline
ORIGINAL: NoTyme
I've heard some people having that issue after they've changed their lights (LED etc)
Old 07-17-2007, 10:52 PM
NoTyme's Avatar
NoTyme
NoTyme is offline
Thats not a good thing. I have been running LED's for over a year. Its kind of a strange thing because this starts whenever the air is very damp or it raining. Just came back from a trip and it started right after I ran into a rain storm, and quit a half hour after it stoped. Also started on one moring that I did not coverthe bikeon the trip, but here at home it's always in the garage.
The numbers I pulled don't seem to match any of the trouble codes themselves. Thats the strange part...
I'll ride it tomorrow and try again!
Thanks
Quick Reply: Security light stays on... ?'s mean
