two ironhead questions...
Old 07-08-2007, 08:46 PM
socobandit's Avatar
socobandit
socobandit is offline
Default two ironhead questions...
OK, I have two questions...hopefully easy to answer. First, my engine is burning oil...most ly when accelerating and changing gears...is this more likely the valve guides or the rings? If it is the guides, is there a seal I can install rather than changing the guides? Second question...for those in an E85 methanol area, have you noticed flat spots on accel? It's only been the last 2 months or so, and without fuel injection, I've really noticed a decrease in power. An help is appreciated, thanks!!
Old 07-08-2007, 08:54 PM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
Default RE: two ironhead questions...
Is it burning large amounts of oil?
While I'm not an Ironhead expert, I have logged over 40k miles on mine. I had a top end job done on it 3 days after I got it. My buddy is an Ironhead guru and did the job. He does not put valve seals on the exhaust guides. He claims the little bit of oil that trickles down helps prevent galling. My bike puffs a bit at an idle and gives off a puff between gears. However, it does not use enough between changes to ever need any oil added.
IMO, if you are using oil and have a decrease in power, you need to be doing a compression check and be considering the possibility of needing a new top end job.
Old 07-08-2007, 10:40 PM
piniongear's Avatar
piniongear
piniongear is offline
It most likely is a bit of each. The rings wear with the milage build up along with the guides. When your guides are worn to the point they let excess oil by, then there is not a seal in the world that will remedy that problem.
The only way you are going to know where the wear has happened is to pull the heads, remove the valves and measure the guide wear. This is of course the time to inspect the valve seats. Chances are better than average that it nees a valve job done.
In fact, if you want to do this inspection, plan on a valve job as part of the operation. You really should not remove the valves without refacing both the valves and the seats before putting it back together.
If you are concerned with the rings, again...the only way to check this wear is to pull both cylinders off and measure. You are not looking to measure the rings, but the cylinder wear. I would stick an ID mike in the bores (top and bottom) to see what the difference is. At a certain point of wear, the only solution is to rebore and install new pistons. If you pull the heads and can feel or see a ridge at the top of the cylinders, then it is not a question of do you need to bore, but rather how much will it take to clean up the cylinders?
We are getting serious here I know, but I am just telling you the way it is. On the otherhand, if you are not in a position to do this inspection now I recommend you just ride the bike and enjoy it. Ironheads can run a long, long time before a little burning oil stops them.
As to your question of the E-85 fuel.......I can only say I can easily live without that stuff. The alcohol destroys O rings and seals in the carb over time. Gimme back the MTBE anyday. Just my 2 centavos here...............pg
Old 07-09-2007, 10:11 AM
crampfan's Avatar
crampfan
crampfan is offline
You should not run E85 unless you have a carb. made for it. S&S has a alcohol carb. although it is a "B" type. E85 has less BTU's so you will run very (VERY) lean unless you jet for it. E85 will not save you any money as once you get jetted, your milage will be in the area of 18 mpg. Until the cost comes down, its just not worth the effort.
Old 07-09-2007, 08:12 PM
socobandit's Avatar
socobandit
well, thank you very much gentlemen...it only puffs a little, so maybe i won't worry about it...as for the fuel concern, i went to the next county and got gas w/o ethanol, and the bike runs alot better. Thanks for the input guys!!
Old 07-13-2007, 03:30 PM
Oldtimer of NM's Avatar
Oldtimer of NM
Oldtimer of NM is offline
A compression test will tell you whether your rings are leaking. Run a test after the bike has been sitting for at least 24 hours, and note the pressure. Then put about a tablespoon of oil down each sparkplug hole and test it again. If the second test gives a significantly higher reading, you need rings.
Old 07-13-2007, 04:59 PM
socobandit's Avatar
socobandit
thanks alot oldtimer...i even work on cars for a living and forgot about that trick...been a while since i had to use it. well, i'll let you all know what happens!
Old 07-17-2007, 10:31 PM
real550A's Avatar
real550A
real550A is offline
Stage IV
Better than a compression test is a cylinder leakage test. It will tell you right away if it's your rings, intake
or exhaust valve. It'smore informativethan a compression test, which will only tell you that you have a
problem. Very easy to do with a leakage tester. Cheap at HF Tools.
Old 07-19-2007, 08:54 PM
socobandit's Avatar
socobandit
Thanks...good idea as well... i have a compression gauge anda leakdown tester, just got to get around to sittin the bike long enough to do it. I have a long summer left to do it, so we'll see what happens in the fall. Thanks!
Old 07-20-2007, 10:22 AM
tedali2004's Avatar
tedali2004
tedali2004 is offline
If you aren't oil fouling the spark plugs, don't rush into tearing the motor down.
cdorsey50stang
Exhaust System Topics
13
02-08-2013 06:53 PM
tc
EVO
05-02-2011 10:35 PM
Sidekicker
Ironhead
04-07-2008 07:39 PM
38knuckle
Shovelhead
04-03-2008 06:20 PM
pyro
Ironhead
11
05-29-2006 01:07 AM
Quick Reply: two ironhead questions...
