Radio Fuse keeps blowing? SOLVED!
Old 07-05-2007, 05:44 PM
fryeca's Avatar
fryeca
fryeca is offline
Default Radio Fuse keeps blowing? SOLVED!
My radio went dead a couple of days ago, I found the Radio MEM (memory) fuse had blown. I went to the dealer and they said that they had never heard of that fuse going before? They gave me a couple of spare fuses just in case it blew again.
Well it blew again; and again. Doesn't matter if the bike is running or sitting overnight in the garage. It doesn't go right away, seems to take about a day then BAM!
Anyone else have a similar problem or fix?
Old 07-05-2007, 05:57 PM
Kahuna's Avatar
Kahuna
Kahuna is offline
Default RE: Radio Fuse keeps blowing?
You have a ground problem somewhere. Have you made any upgrades/changes recently? Did you remove/install a seat recently? You can also have a wire chafed through vibration that it's grounding on the frame or other metal area. Don't blow another fuse. Spend time and trace the wiring with a meter.
BTW, what bike are we talking about here?
ORIGINAL: fryeca
Old 07-05-2007, 06:07 PM
fryeca's Avatar
fryeca
fryeca is offline
Thanks Kahuna,
2006 Strret Glide. I've installed Cruise Control, Fog Lights with internal wiring at the engine guards (I tied into the seat heater ACC switch for the fogs).
I'm going through the schematics right now.
BTW I used to be an Aircraft Elelctrician in the Navy and then spent another 10 years as a Plane Captain on A6 Intruders Northrop Grumman(total of 18 years) I hope I still have the touch!
Old 07-05-2007, 06:17 PM
electra trike's Avatar
electra trike
electra trike is offline
The bikes still under warrante take it back to the dealer let them fix it. Unless your like me take the fairing apart and let the fun begin. Good luck?
Old 07-05-2007, 06:23 PM
fryeca's Avatar
fryeca
fryeca is offline
I have a really good dealership but don't like any one else wrenchin' on my bike unless it's completely out of my capabilities.
The fairing has been off this bike a bunch already...all three fairing support structures have failed at least twice? I keep getting new horizontal supports from dearler and made a MOD to the vertical support myself, never broke again.
Old 07-05-2007, 06:27 PM
electra trike
Then enjoy the hunt for the short
Old 07-05-2007, 06:29 PM
fryeca's Avatar
fryeca
fryeca is offline
Thanks! The TRON chasing will begin at 0630 Friday morning
Old 07-06-2007, 09:44 AM
fryeca's Avatar
fryeca
fryeca is offline
Round ONE! Zero for me; 2 for the bike. Still have the fuse problem; but it takes a few hours for it to blow? Looking more like the radio to me.
While I was looking for shorts under hte fairing I found ANOTHER broken fairing strut...[:@]
Fourth one so far? I think I'll MOD this one with some aluminum stiffeners and be done with it.
Old 07-09-2007, 06:03 PM
fryeca's Avatar
fryeca
fryeca is offline
I've wooped all the majic I can on this one[:@]
I disconnected the radio and the fuse stopped blowing, gotta be the radio, this will be the third this bike has seen[sm=shootshoot.gif][sm=shootshoot.gif]
Old 08-02-2007, 01:38 PM
fryeca's Avatar
fryeca
fryeca is offline
Radio fuse SOLVED!
Found left horiznotal faring bracket craked AGAIN! Radio wires were chaffing on this bracket while it was flopping around.
Replaced backet for the sixth time and put heat shrink on wires...just in case it breaks again; who am I kidding, of course it'll break again.
There's gotta be a better fix than constantly replacing these brackets...?
Quick Reply: Radio Fuse keeps blowing? SOLVED!
