Question: Ignition switch/Fairing cap removal 2007 StreetGlide
Old 06-29-2007, 11:22 AM
dionne51's Avatar
dionne51
dionne51 is offline
Default Question: Ignition switch/Fairing cap removal 2007 StreetGlide
Anyone know if I have to use the HD tool specified in the service manual to remove the ignition switch (base, not the switch itself....that is easy). I installed my aux lighting kit last night and ended up having to keep the fairing cap in place and accessing the switches from behind/underneath with a little bending of the plastic.
Install is done but if I need to add another switch at a later date I would like to be able to get the fairing cap completely removed. I believe the '06 models just had a nut to remove once the switch was off but with the '07s a special tool is listed to remove the switch body.
Old 06-29-2007, 12:30 PM
Rodman813's Avatar
Rodman813
Rodman813 is offline
Default RE: Question: Ignition switch/Fairing cap removal 2007 StreetGlide
yes, "I" would recommend gettingthe tool........I didn't....Thank God I was able to use a screw driver to move the lever/cams down in the hole back to the proper position so that I was able to put the swtch back in..and unlock my folks..
I will get the tool next time, because it was luck this time.....so the tool will serve multiple purposes....
Old 06-29-2007, 02:42 PM
dionne51's Avatar
dionne51
dionne51 is offline
I was able to get my switch out and then back in with no issues, just couldn't get the darn body off itself. From the picture the tool sort of looked like a fancy screwdriver, I never did flash my light into the switch body to see what was in there but the mechanics of the switch itself pretty much said to me 'don't even touch this thing'
D
Old 06-29-2007, 02:56 PM
Sharknose's Avatar
Sharknose
Sharknose is offline
If you're talking about the "ignition switch alignment tool", the answer is "no". You can use a medium sized flat blade screwdriver to turn the deepest "tumblers" and the shaft of the switch itself to turn the upper ones.
Old 06-29-2007, 04:04 PM
04harleyboy's Avatar
04harleyboy
04harleyboy is offline
I agree, you do not need the tool. I helps to shine a light up from the bottom to align them.
Old 08-14-2007, 12:05 PM
rome304's Avatar
rome304
rome304 is offline
any one have part# of tool needed.
Old 08-14-2007, 12:28 PM
Akitakoi's Avatar
Akitakoi
Akitakoi is offline
ORIGINAL: rome304
The only tool you need is your key!
just plain john
11-23-2014 07:24 AM
Bo Joe
04-07-2013 03:39 PM
Shrug
06-07-2010 12:51 PM
Big Chris
05-07-2010 12:12 PM
bldap
10-11-2009 08:50 AM
Quick Reply: Question: Ignition switch/Fairing cap removal 2007 StreetGlide
