Oil change and Trans change on 2006 Fatboy
Old 06-27-2007, 08:57 AM
law14w's Avatar
law14w
law14w is offline
Default Oil change and Trans change on 2006 Fatboy
I want to thank everyone that helped with my oil change questions. I am posting this to put the information I received in to one post.
Tools needed 3/8 allen for the tramission fill stick,and smaller allen for the engine oil bolts and drain plug
you have to put a mirror underneath the bike if it's on the jiffy stand. once you put a mirror you will be able to see the bolt between the shocks. This bolt is the tramission drain plug. I had to crank on this bolt to loosen it, b/c the loctite on it. Don't do what I did. I was looking in the mirror cranking on this bolt. Well silly you have to remember everthing is opposite when your looking in the mirror. so if your going right in the mirror you actually want to go left. I guess I shouldn't have smoked before i started this project. Anyways I drained the oil and that **** was dirty. That was my first change at 7,ooo miles. I know I shouldn't have waited that long. I changed the Engine oil at 3,000 then at 7,000. The oil is easy to change on my bike. The drain plug is on the pipe side in the back corner underneath the bike. Use the allen to loosen it and drain. I used a turkey roasting pan tenfoil for a oil pan. The owners's manual did not help me very much at all. I owe all to the people in this forum that helpled me. I saved $189 dollars. That is what the stealer wants fora oil change. Again thank you for all your help. FYI my bike takes 3.5 quarts of engine oil. 20w 50. My trans takes 26oz of transmisson/primary oil. I use Harley Davidson.
GittinThere
Oil Archive (no new posts)
22
05-08-2022 04:47 PM
bubdifab
07-17-2013 06:52 PM
John D
05-03-2012 10:00 PM
keeferfish
15
08-04-2011 08:50 AM
Mattee23
06-19-2011 05:49 AM
Quick Reply: Oil change and Trans change on 2006 Fatboy
