Widest tire I can put on my FXD
Old 06-21-2007, 11:38 PM
fxdave's Avatar
fxdave
fxdave is offline
Default RE: Widest tire I can put on my FXD
i have a 2001 wideglide stock is 130 what is the widest i can go with a metzler and no other mods
Old 06-24-2007, 10:50 PM
blackv03's Avatar
blackv03
blackv03 is offline
Would it be possible to convert an 2003 dyna to the smaller belt size that I see on some bikes now? other than a new rear pulley, what would I need? Anyone care to chime in on this idea?
Old 06-24-2007, 11:55 PM
wlbowers's Avatar
wlbowers
wlbowers is offline
ORIGINAL: sharkey
Here's a 160/60ZR 18" on the back of my stock fendered '01 FXDXT...using a 4.25X18" rim...
[IMG]local://upfiles/32069/EB65721CAB09447BAA0D7D5E13E78A92.jpg[/IMG]
Then it is not stock. That rim didn't come on that ride. Did it.
http://www.dunlopmotorcycle.com/fitmentguide.asp
Dyna Super Glide T-Sport
Front Rim Size: 2.15x19 | Rear Rim Size: 3.00x16
Old 06-25-2007, 12:14 AM
blackv03's Avatar
blackv03
blackv03 is offline
What is the largerst tire I can put on a 3.00x16 rim? Would a 180 even fit?
Old 06-25-2007, 12:40 AM
wlbowers's Avatar
wlbowers
wlbowers is offline
ORIGINAL: blackv03
Metzler
ME 880 MARATHON
Front 100/90-19 M/C 57H TL ME880 FRONT - 38 PSI - 3.0 INCHES
Rear 160/80B16M/CTL 75H ME880 - 40 PSI - **
Remarks: Stage 1
Remarks:
** Desinates special tire fitment on O.E. rim.
Front 100/90-19 M/C 57H TL ME880 FRONT - 38 PSI - 2.15 INCHES
Rear 150/80B16M/CTL 71H ME880 - 40 PSI - 3.0 INCHES
Avon Fitments For Harley Davidson
FXDL Dyna Low Rider (2002 - 2005)
Front Tyres
» Venom Size 100/90-19 57H (also WW) 2.5 bar (36psi)
Rear tyres
» Venom Size 150/80B16 77H, 77V (also WW) 2.8 bar (40psi)
Old 06-25-2007, 08:54 AM
DGlide04's Avatar
DGlide04
DGlide04 is offline
I've been running a 160 mm Metz on the back of my '04 FXD for a few thousand miles and over a year and no problems. You could put on a 180-16", but it won't fit the wheel properly and may have other problems. An 18" wheel with a lower profile tire will work, but on a stock rim, 160mm is about it. You can go to a chain or narrower belt as has been suggested, but again, that will involve more mods than just a tire change.
Old 06-25-2007, 09:38 AM
blackv03's Avatar
blackv03
blackv03 is offline
maybe a low profile tire is the answer ... the thing is, its only about an inch to go from a 160 to a 180, is it really worth the extra cost if I have to buy a new rim and change the belt, etc? I'm not so sure !
Old 06-27-2007, 09:43 AM
Patch's Avatar
Patch
Patch is offline
I have a 2005 FXDCI with a stock rear tire size of 150.
I would like to go with the Metzler 160...BUT I don't know what they mean by "special fitment?"
Does anyone know what they mean by that?
Also in looking at the rear tire to fender clearance I noticed that the tire/wheel in not centered to the fender. Is this normanl?
There is less clearance on the left side???
Old 06-27-2007, 10:23 AM
glide05's Avatar
glide05
glide05 is offline
ORIGINAL: Patch
I went back and forth with Metzeler tech support via email on this issue. He kept telling me that everything I needed to know was in the documentation on the Metzeler website. My reply was that in one place it says a 3.5" wheel is required for the 160, in another place it talks about "special fitment" using the stock 3" wheel.
Here is the reply I got:
"On pages of the fitment area we note that the 160/80-16 is a approved fitment for the 3.00 rim on many Harley applications as in (# designates special tire fitment on OE rim.) This note is shown to state that there is an exception of rim width for the bikes listed in the fitment area. That's it and thanks for asking more clearly."
So - I felt better about trying this after his reply, but I am much more confident it will work after reading several posts in this thread where others have done it. I was most worried about belt and fender issues.
I can't wait to get this done - trying to find the time. Put a Metzeler on the front last weekend - far superior ride to the Dunlop.
Old 06-27-2007, 11:48 AM
blackv03's Avatar
blackv03
blackv03 is offline
the difference between a 150 and a 160 is less than 1/2" in width, hardly noticable ... going up to a 180 gains you a little over an 1" of width ... I'd be more interested to know if I could use say a Deuce wheel with the 180 on my Lowrider .. anyone have that set up??
Quick Reply: Widest tire I can put on my FXD
