Road King Oil Change
Old 06-06-2007, 08:37 PM
Unclenuts's Avatar
Unclenuts
Unclenuts is offline
Default Road King Oil Change
Hey Gang:
Where can I find a pic or diagram showing the oil plugs I need to remove to change the oils in my 2005 Road King?
Thanks
Dave
Old 06-06-2007, 08:48 PM
jack49's Avatar
jack49
jack49 is offline
Default RE: Road King Oil Change
You should get a service manual,makes life easier and will save you a lot of grief.
Old 06-06-2007, 09:16 PM
sportyrider1's Avatar
sportyrider1
sportyrider1 is offline
ORIGINAL: jack49
Ditto but if you insist on not getting the book right now the crank case oil plug is on the front left corner of the transmission pan (3.5 qt's) the tranny plug is center further back(I dont rember how much right now)and the primary plug is under the derby.( 1qt)
Old 06-06-2007, 09:33 PM
harleyrobert4's Avatar
harleyrobert4
harleyrobert4 is offline
With the service manual, I highly suggest the "Fix My Hog" dvd. It will go through the service step by step in good quality detail.
Those two items will be some of the best money you will ever spend for your motorcycle. Good luck on the service.
Remember:The twin cam 88 need a derby cover gasket, timing chain cover gasket (adjust timing chain in 1 in incraments), oil plug o-ring, tranny plug o-ring, primary o-ring.
Old 06-06-2007, 10:01 PM
Time2ride's Avatar
Time2ride
Time2ride is offline
Don't know about the 05, but in the 07 owners manual the diagram is in the maintence section.
Old 06-06-2007, 11:30 PM
Dave_E's Avatar
Dave_E
Dave_E is offline
Owners manual, but better yet, service manual!
Old 06-07-2007, 12:41 PM
berettag's Avatar
berettag
berettag is offline
We just had a thread asking the same question about a week ago. Do a search, there where pictures of the plugs included in one of the responses. And ditto the manuals. Might wanna search for how to repair a stripped out plug too.
Old 06-07-2007, 05:43 PM
murph3204's Avatar
murph3204
murph3204 is offline
Use a torque wrench to tighten as specified in the Service manual and you won't have to worry about stripping the threads.
Harlynewbie
Oil Archive (no new posts)
05-06-2011 10:04 AM
aeromass
08-21-2010 07:55 PM
Ghost2277
08-13-2010 11:50 AM
Hamdog
06-22-2009 05:34 PM
FloridaRKrider
08-04-2007 08:02 PM
Quick Reply: Road King Oil Change
