Oil Drain Plug
Old 06-03-2007, 10:22 AM
dedaughe's Avatar
dedaughe
dedaughe is offline
Stage I
Default Oil Drain Plug
I just got a 2001 Road King and would like to change the oil but I can not find the oil drain plug. I was hoping for some help to let me know where it is located.
Old 06-03-2007, 10:37 AM
billnourse's Avatar
billnourse
billnourse is offline
Default RE: Oil Drain Plug
Under the bike on the pan. It is the one that is a little on the left side of the pan facing to the front. The one that faces straight down is the transmission. The plug will require a 5/8" socket. It also has a 1/4" allen wrench recess in the center of the plug.
If you are going to do your own maintainance, you really need to get a shop manual. It will have all the info you need to change oil, adjust belts and chains, align rear tires, change tires etc.
Bill
tjmac49's Avatar
tjmac49
tjmac49 is offline
Two (2) plugs on the base of the oil pan; the one most forward and inboard is the oil drain plug; the plug towards the outside and more to the rear is the transmission drain plug. Hopes this will help.
Old 06-03-2007, 11:00 AM
cubcake1's Avatar
cubcake1
cubcake1 is offline
I just got the FIXMYHOG dvd and it is great for general information like this. Worth the $50. ALso get a manual.
Old 06-03-2007, 11:10 AM
Puzzled's Avatar
Puzzled
Puzzled is offline
This may help you out.
[IMG]local://upfiles/25024/E58EAD52FD7748068ED77A5D0AD10D0D.jpg[/IMG]
petdoc94
Oil Archive (no new posts)
33
09-07-2020 07:34 AM
PhatBoyHigh
11-25-2015 11:11 AM
abrahamseven
15
07-18-2010 03:48 PM
mikes4692003
Engine Mechanical Topics
08-11-2009 02:53 PM
michael_a_anderson
04-24-2007 11:04 PM
Quick Reply: Oil Drain Plug
